moving a sessions from PTLE (pc) to mix plus (mac)
Hello nice duc people. I have been given the opportunity to re-mix and master on a mix plus system. Here is my problem; I am running a 001 with a pc (ptle 5.0.1) ... and need to know how to convert sessions so they work on a mac based mix plus system. I believe the mix plus is running the latest os and pt 6. I hope this all makes sense, as I am a bit of a novice! Thanks in advance Paul.
AMD 64 3700+ DFI LanParty nF3 250gb Mobo Corsair XMS3200XLPT (2 x 512) Ram 2 x WD caviar 7200 80gigb win xp sp2 ptle 7 DAVEC 32 + 28 |
Re: moving a sessions from PTLE (pc) to mix plus (mac)
In the File menu select Save Session Copy In... and check the Mac/PC compatible checkbox.
This is an FAQ BTW - a search will garner you many previous responses to your question. Rail
thanks rail
did try a search but came up empty handed... will try again thanks for the help paul.
When searching make sure you set the right boolean operator.. it defaults to 'phrase'.. set it to 'and'.
BTW for Mac/PC compatibility you'll need Pro Tools 5.1 or later. Rail
ok.. so i have to upgrade to ptle 5.1 ( i guess there is a patch i can download ?? )
thanks for your help rail paul
Moving sessions between 8.04 and 9 | Talisker | Pro Tools 9 | 1 | 11-09-2010 08:19 AM |
moving sessions to ext. hd | cjac9 | Pro Tools M-Powered (Mac) | 4 | 04-15-2008 02:47 PM |
moving sessions | john1192 | Pro Tools TDM Systems (Mac) | 0 | 11-17-2003 12:30 PM |
Moving Sessions Around.. What to look out for please? | paul c | Pro Tools TDM Systems (Mac) | 1 | 10-10-2002 08:44 AM |
moving sessions... | Karrot24 | General Discussion | 4 | 08-04-2001 07:08 PM |
