Old 05-15-2019, 01:19 PM
digifactory digifactory is offline
Default No sound via headphones (iMacPro with PT 2019.5) (SOLVED)
Hello,
I have installed PT 2019.5 on a fresh iMP (Mojave 10.14.5) and I am not able to get any sound via the connected headphones. I am not using any interfaces or monitors yet.
Playback via iTunes works without any troubles. If headphones connected, sound via headphones, if not, sound via internal speakers, as expected.
In Mojave System Preferences/Sound/Output I can choose between
External headphones (selected atm)
iMac Pro speakers
Pro Tools Aggregate I/O
Within PT Playback Engine the following options are available:
Pro Tools Aggregate I/O (selected atm)
External Headphones
iMac Pro Microfone
iMac Pro speakers
I tried several combinations, as well as External Headphones BUT I do not get any sound via headphones, only via speakers all the time.
I deleted everything within Setup/I/O Settings of PT and choose Default but still no sound via headphones.
Which settings have to be done to get any sound via headphones within PT
Any help highly appreciated.
Regards
Composer/Keyboarder
iMac Pro 10 Core 64 GB RAM Vega 64
Pro Tools 2023.12/Ventura 13.6.1
Beyerdynamic DT 770 Pro
______________________________
Old 05-15-2019, 02:41 PM
K Roche's Avatar
K Roche K Roche is online now
Default Re: No sound via headphones (iMacPro with PT 2019.5)
Your post is not real clear
Are you saying you get PT sound with the iMac internal speakers but not the headphone jack ?
"BUT I do not get any sound via headphones, only via speakers all the time".
If that is case then I am not sure what the problem is
But If you are not getting any sound from PT perhaps try this
http://avid.force.com/pkb/articles/e...nput-on-Mojave
System :
Enjoy the Journey
.... Kev...
Old 05-15-2019, 03:02 PM
Right, no sound via headphones within PT, but via internal speakers.
The headphone jack and the headphones are working fine because I am getting sound via iTunes e.g.
Thank you, but your link refers to an audio input issue. I have an audio output issue.
Regards
Composer/Keyboarder
Old 05-15-2019, 03:09 PM
(Mis) behaving as expected...
https://www.google.com/amp/s/www.cul...l-outputs/amp/
Basic apps treat these as a single output, more complex apps.. it’s up to you.
Old 05-15-2019, 03:33 PM
685 685 is offline
Does the volume level show onscreen when making volume adjustments after the headphones are plugged into your Mac?
Old 05-15-2019, 03:36 PM
Thank you for the link, darryl. Explained a few more things to me.
Restarted my machine, deleted all the prefs and picked "external headphones" in OSX-Sound-Output-System Preferences and PT Playback Engine and now I am getting sound through my headphones :)
Composer/Keyboarder
Old 05-15-2019, 03:46 PM
Great. I remember Apple doing this in some recent models, had to Google to see if it was done in yours and found that handy article.. It’s a nice thing they actually did (for a change.... give me back my Mini-TOSLINK output... grrr).
Surround sound mix for headphones fretfingers AAX Plug-ins 10 07-17-2014 04:00 PM
No Sound Through Headphones houser8732 Windows 12 11-02-2013 01:20 PM
no sound from headphones? Darkk927 Pro Tools M-Powered (Win) 2 04-23-2008 08:07 AM
no sound from headphones simon123456789 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-19-2008 05:18 PM
5.1 surround sound headphones manis Post - Surround - Video 19 01-10-2008 04:49 AM
