switching between stereo and direct otputs
With v 5.01 i was able to switch from stereo to direct ouputs (under prefrences>operation) with version 5.1 i don't see that option in my prefrences. Am i missing something here??
Re: switching between stereo and direct otputs
With the new I/O setup that is really not necissary now. You can set up your paths as 4 sets of stereo outputs, and then add 2 sub-paths that each contain one mono output from the stereo pair. After you do that the output selection drop down menu on the channel strips should show you all of the possible stereo paths, with any mono sub-paths created along with them.
Example: I go into the output panel on the I/O setup preference window. I click the New Path button. On the new path that was created I make sure that the Stereo/Mono Selector is set to stereo, and click on the square under output #1. I now have a stereo path going to outputs #1 & #2. With my new stereo path's name selected I click on the New Sub-Path button. I now click on the square under either Channel #1 or #2, and that creates the mono path to that channel. I create a new audio track, and when I click on the Output selector I am given the choice of Analog 1-2 (etc.), >Analog 1, >Analog 2. If I choose Analog 1-2 it is stereo as usual, if I choose Analog 1 it is just like direct outputs. Hope this helps.
Shawn Parr Muskrat Studios |
Thanks for the help. Should have realized the answer was right in front of my face
Switching heat to pre after mono to stereo plug = crash | crizdee | macOS | 0 | 01-14-2012 01:30 PM |
Stereo image of direct recording | Ping Pong | Tips & Tricks | 3 | 08-11-2004 08:00 AM |
Apogee Rosetta vs. Mytek stereo AD - direct AB ! | ISedlacek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-11-2003 09:10 AM |
Pro Tools goes Pro! Finaly, pec-direct switching | tomcat | Post - Surround - Video | 28 | 10-20-2003 03:07 PM |
switching from surround to stereo | agus | ProControl, Control|24, Command|8 | 4 | 01-26-2001 12:39 AM |
