XP Problem, any clue?
Hi
Just installed PTLE 5.3.1 on my XP system. Got the following error after reboot, once the installation program was finished. IRQL_NOT_LESS_OR_EQUAL Sounds like som IRQ error, but haven't changed anything since I ran it in WinME. I run a AMD XP1900 with a VIA333 chipset. Worked nice in WinME... Any ideas? A solution would be lovely to hear! =) Rgds, /Staffan Kerker Sweden |
Re: XP Problem, any clue?
if you go to the microsoft support pages and search for that error, i believe you might find a solution.
~matt |
Hm, I thought so too. Got a whole bunch
of hits but hard to find any clues to a solution to my problem... I now have the Digi001 installed in my XP, but not completely, PT can't run and I can't use the DIGI... but XP device manager says that everything is fine with the installed Digi 001.... something is very strange... |
The solution given by Microsoft knowledge
base is basically: "Get a correct device driver"... and so I hope I had from Digidesign... |
One of the beta testers solved this error by disabling his RAID controller.
-- Mike - HP Spectre x360 Convertible 14t-ea100 - 2.9 GHz (5.0 Max Turbo) i7-1195G7 32GB RAM, OLED 3k x 2k, Iris Xe Onboard Graphics - Windows 11 - PT 2021.12 - PreSonus Quantum 2 - PreSonus Studio 24c - Mackie Onyx 1640i - Samsung T3 and T5 SSDs - Various USB2/3 and Firewire HDDs |
I disabled my RAID controller as well and now
I got rid of that problem... instead I get the following upon launching PT after a now successfull installation and reboot. "This software requires installation of certain device drivers and a rebooting before running. Please reboot or reinstall software." Not this happends every time, after a few reboots, and the device manager shows that the DIGI i successfully installed... hints? do I need to have the WaveDriver installed as well? |
I believe you do. The new wavedrive is a separate download from the 5.3 download. If you go to where you can download the 5.3 there is mention of this and where to get it.
ASUS A7N8X-E Deluxe MD Athlon XP3200+2.20GHZ Corsair XMS PC3200 400MHZ 1GB WD EIDE 10GB WD EIDE 250GB XP Pro SP1 ProTools LE 6.4 |
hm, that's not it.. installed the Wavedriver as well... eveything looks good but still the same problem. PT won't launch, and as I try to run other applications, say WinAmp through my Wavedriver it can't aquire the hardware...
just saw that digitest stalls on final test (7/7) never done that before... what is that test? |
Any Clue when the 004 will be out? | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 01-07-2011 02:56 PM |
ok can someone please clue me in... | keny | Pro Tools TDM Systems (Mac) | 1 | 07-16-2009 10:27 PM |
Looks like Someone has a clue | FatBelly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-03-2008 04:34 PM |
Does anyone have a clue... | soundboy69 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-20-2003 05:30 PM |
I have no clue? | robby | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-15-2002 12:47 AM |
