Dither vs, POWrDither
what is the difference?
and should i use either if i just want to convert the WAV. into MP3 (i dont have MP3 option) not to a CD |
Re: Dither vs, POWrDither
I would also like to know the difference between Dither and POWrDither.
MBox 2 Pro connected to motherboard 4 pin firewire port Dell Inspiron 9300 laptop 2.0 gHz Pentium M 2 gB ram Lacie Rugged 5400 rpm firewire 800 on Siig Cardbus adapter Roland 700SX stage piano Studio Projects C3 mics Melodyne Plugin Dual Boot: PTLE 8.0.1 on Windows 7 Enterprise 32 bit PTLE 8.0.1 on XP Media Center SP3 |
http://www.digidesign.com/index.cfm?...&categoryid=37
Try the Digirack Plugins Guide v7.4 (PDF) page 59 -60. I'm still none the wiser.
MBox2Pro / LE 8.0.5 |
When POWr first came out, it was widely praised by a number of top mastering engineers as being the best yet. There are others out there now that are at least as good, but POWr is generally superior to Digi's dither. Try the different settings if you want, but 2 works well for practically everything. Use 1 for spoken word. Use 3 for classical or acoustic where there's huge dynamic range and a sensitive stereo image. Other than that, use 2 unless you're sure you hear a clear improvement with 3.
Your other question is a little tricky to answer. The straight answer is, you need dither any time you're reducing bit depth. If you're going from 24 to 16, you always need 16-bit dither as the last plug-in on the master fader. It recently became possible to make mp3s from 24-bit files. I'm not sure what happens when you do that. It probably depends on your codec. Does it accept the 24-bit file, but truncate it to 16 prior to conversion? Does it make full use of the extra resolution to encode more intelligently? I have tried to find answers to those questions for iTunes, but no luck so far. So, to be safe, I always dither down to 16-bit for making mp3s. YMMV.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
What is the benefit of dithering?
i know this is a newbie question, but if my ending bit rate is going to be 16, why not track in 16? i am assuming that there are sonic benefits to tracking in 24, but not sure what they are? Be kind...help a newbie out. Thanks in advance. |
16bit vs 24bit
Kryst |
Can Dither in Export Prefs be changed to PowR Dither | Mr. Anxiety | Tips & Tricks | 5 | 10-31-2009 10:28 PM |
Dither ... placement of the dither plugin. | tpthai2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-12-2007 07:20 AM |
DITHER Pow-r dither v.s. Apogee UV22 | sukks2bu | Pro Tools TDM Systems (Mac) | 0 | 10-13-2004 08:01 AM |
PT DITHER x masterist dither x TC masterxdither x l1, q10 dither | Alécio Costa | Tips & Tricks | 9 | 02-24-2002 01:28 PM |
Is the Waves IDR dither better than the Masterlist CD dither? | vtone | Digidesign Hardware & Software | 12 | 10-12-2000 02:47 PM |
