Cannot record enable TWO midi sources at once
Hi!
I am using a Roland digital drum set to trigger Superior Drummer, and I am using a Roland midi keyboard to trigger Xpand2 in Pro Tools 12.4. Both are connected to my pc via USB cables. Ive tried being really thorough when setting up each tracks channels etc. When I hit recordenable on the drum track, the xpand track no longer recieves any signal input from the midikeyboard and vice versa. In short - I cannot recordenable both tracks and have 2 midi inputs at the same time, the first track will loose its input signal when I recordenable the other. Is there any way around this? When I jam with my friends in my studio I really want to have output from drums AND synth at the same time. Thank you kindly for any and all input! -Cris
Pro Tools 12.5 || RME Fireface 800 || Intel Core i7-6800K Prosessor || MSI X99A RAIDER, Socket-2011-3|| HyperX Savage DDR4 2400MHz 16GB || Win 7 SP1 || |
Re: Cannot record enable TWO midi sources at once
Can you post a snapshot of the tracks showing the MIDI I/O settings?
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
One of the modifiers will let you record enable multiple midi tracks. Try clicking the record enable buttons while holding the alt or cmd or ctrl key.
It's shift for contiguous tracks and command for non-contiguous tracks.
Dave Marsden UK |
My setup is on Windows so Mac may be slightly different, but here is the trick. Under the Midi Studio setup, once bothe controllers are listed, on the TD kit, deselect all midi channels EXCEPT for 10. On the keyboard, deselect 10. Now on your 2 instrument tracks(mix window shows "instrument "), go to the top box(this only shows on the Mix window), and set the Hybrid track to the keyboard, and the drum track to the TD unit. alt-click on either track's record button to enable both.
By default, all instrument tracks will receive any midi, so doing the above allows for separate instruments at the same time. I tracked drums with a Roland kit, piano with a Motif es8 and DB-33 from a 3rd keyboard, all at the same time
It's just shift clicking additional record enable buttons. Command will disable the ability to record on that track(bypassing the record enable function)
MIDI Record enable behavior | DetroitT | Pro Tools 10 | 6 | 06-29-2013 07:14 AM |
MIDI vs AUDIO Record Enable | HearInc | macOS | 4 | 04-04-2013 03:07 PM |
Audio and MIDI grp wont record enable | drewsmith | macOS | 4 | 07-23-2011 02:59 AM |
Protools 7.4 midi record enable problem | maisbass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-06-2007 08:33 AM |
how would I record two midi sources? | keithl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-28-2007 08:28 AM |
