Old 02-24-2020, 09:38 PM
mattrixx mattrixx is offline
Default Attention Strip on Dock and Logic Pro X (Eucon 20.1.0.50)
Hi there,
Can anyone replicate an issue I am seeing with my S3, Dock setup?
No matter what track I select (regardless of the Dock fader assignment being attentioned track). It will only show the first top most track in the Arrangement Window - in both the App and the Dock. Can't be changed, unless manually re-assigning in the layout in Eucontrol. However, then, the fader goes to the correct track, but the App displays only the first track still.
I've also tried changing the order of the devices in the Eucon Surfaces window to no avail.
[edit] A restart of Eucon seems to sort it out for a while, but I'll leave this here, as the problem comes back after a little while.
Regards,
Matt
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
EUCON - attention FIRST track of the group, not the LAST psycho_monkey Artist Series 3 04-01-2020 02:57 PM
Dock Channel strip LED don't work Artis Avid S1, S3, Dock and Control App 18 02-14-2020 01:06 AM
Dock attention fader not writing JanuS Avid S1, S3, Dock and Control App 4 02-13-2020 01:53 AM
Attention/Selected Track not working on dock feakerboo Avid S1, S3, Dock and Control App 10 02-12-2019 01:28 PM
Dock Fader - Attention Problem spoons Avid S1, S3, Dock and Control App 6 05-15-2018 07:04 AM
