Bug report: VCA won't follow group
I just stumbled upon this:
I have a drum mix group that has different types of tracks in it- some audio, some aux and one VCA. They're grouped together (not set to follow global) and set to follow volume and mute. When I ride any fader in the group, the VCA one doesn't follow. When I ride JUST the VCA, the rest of the group doesn't follow. That's a new one...
Lior HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 * iPad Air/Avid control * EuCon 18.3.0.217 * |
Re: Bug report: VCA won't follow group
VCAs supersede mix groups.
1) is your VCA part of the group you are trying to control ??
2) when i remove the VCA from the group the VCA moves all the other faders 3) the other tracks (other than VCA) work properly .. you can move them within the group tied to the VCA .. so, i do not think this is broken .. what did i miss in testing this ???
is this normal behavior ??
i need to bone up on VCA's as i do not seem to be much help and do not want to waste your time ..
VCA's are a great way to do a little different kind of automation on faders brought over from my mixing-on-SSL-days...
time to crack the manual !!!
bug report-- solo playlists among grouped tracks only works if mix group is selected | Gems Records | Pro Tools 11 | 4 | 12-26-2013 09:21 AM |
New group default to "Follow Globals"? | reichman | Post - Surround - Video | 0 | 07-05-2011 12:35 PM |
1 track in group isn't responding with group! | gregwor | macOS | 7 | 01-25-2011 07:22 PM |
Follow up please | Fastermouse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-20-2008 10:45 AM |
Group Persists for Resizing Even When Group Turned Off. | holden | Pro Tools TDM Systems (Mac) | 3 | 06-24-2008 03:31 PM |
