Old 07-12-2010, 10:44 PM
gclef101 gclef101 is offline
Default Using UAD 2 With Euphonix
Is there anybody using Euphonix MC Control and MC Mix and UAD 2 together? Do the plug-ins map well with control surface? Any issues? Thanks!
Old 07-13-2010, 12:45 AM
maxtn maxtn is offline
Default Re: Using UAD 2 With Euphonix
UAD 1 x 2 works great with PT, Logic and Cubase here.
System#1
PT 10HD Harpertown Lion
HD4 Accel Magma PE6R4-I
Motu PCI-424e
ProControl 32 Faders
System#2
PT 11 and 10.3.6 2012 Westmere Mountain Lion
HDX
MC Mix - MC Control - MC transport - MC Mix with Command 8
Old 07-14-2010, 06:53 PM
DanielEUCON's Avatar
DanielEUCON DanielEUCON is offline
Exclamation Re: Using UAD 2 With Euphonix
Plug in parameters are passed to the host which them displays them to the EuCon adapter.
EuCon does not talk directly to any plug ins.
If there are any isses with parameters, values, feel, etc.. it isan issue in the data between the host DAW and the 3rd party plug-in.
Old 09-17-2010, 04:32 AM
440Hz's Avatar
440Hz 440Hz is offline
Ok so for example....
Using an MC Mix and controlling UAD2 Neve 1081 the LINE (input) rotary knob on the PLUG IN is controlled by a SOFT KNOB on the MC Mix. However it only works as an ON/OFF type control (by pushing the knob) not as a sweepable potentiometer as the plug in suggests and is only controllable via a mouse.
There are quite a number of these situations when trying to control plug in parameters.
Is there a way to map the various control parameters to tactile controls on the MC Mix (that suit the control function ie Soft Knob controls a POT, button controls a BUTTON)
Cheers
440Hz
Yarra Valley, Melbourne, Australia
Mac Pro 2,1 Dual Quad Core 3GHz 18 GB RAM
OSX 10.9 Maverick's
3 x 1TB SATA 1 x 250 GB SATA (Seagate)
PT 12.6.1 HD
MC MIX
RME UFX, Ferrofish A16 AE
MIDAS Venice 320
"The music business is a cruel and shallow money trench, a long plastic hallway where thieves and pimps run free, and good men die like dogs. There's also a negative side." Hunter S. Thompson
Old 09-19-2010, 10:14 PM
440Hz's Avatar
Euphonix?
440Hz
OSX 10.9 Maverick's
PT 12.6.1 HD
MC MIX
MIDAS Venice 320
Old 10-04-2010, 08:58 PM
440Hz's Avatar
BUMP.....
Would be nice to get some SUPPORT or at least an answer?
440Hz
OSX 10.9 Maverick's
PT 12.6.1 HD
MC MIX
MIDAS Venice 320
Old 10-05-2010, 02:45 PM
snake doc snake doc is offline
Are you paging over to see the rest of the controls for the plugs?
www.christurbiville.com
Old 10-06-2010, 08:12 PM
440Hz's Avatar
Thanks snake doc!
Will try that out when I'm next in the studio.
Very new to the MC Mix and still finding my way.
Much appreciate the help!
440Hz
OSX 10.9 Maverick's
PT 12.6.1 HD
MC MIX
MIDAS Venice 320
Old 10-07-2010, 12:56 PM
It does get a little weird hunting for the parameters to adjust
It took me forever to figure it out. The page right and left button will be lit if there are more parameters to view. Once you find what you want to adjust and your done, hit the button labeled "top" I think, to get out of the page views.
Old 10-10-2010, 11:42 PM
440Hz's Avatar
In the case of the UAD2 plugs there are no more available parameters via the page buttons.
Check this link on the UA Forums
http://www.studionu.com/uadforums/vi...hp?f=2&t=14291
cheers
440Hz
OSX 10.9 Maverick's
PT 12.6.1 HD
MC MIX
MIDAS Venice 320
Euphonix with C8 FluffyPost ProControl, Control|24, Command|8 0 04-05-2012 11:41 PM
PT 8.0.3 - no more Euphonix MC Mix! JustinA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 12-23-2009 02:32 PM
Euphonix MC+MIX and PT8 manciosax ICON & C|24 5 10-16-2008 08:47 AM
7.4 HD and Euphonix MC Mix Siegfried Meier Pro Tools TDM Systems (Mac) 3 08-26-2008 03:45 AM
Euphonix MC... Kelly M. Pieklo Post - Surround - Video 20 01-25-2007 11:56 PM
