#41
Re: HDX and HD 44.1 and 48k in and out latency?
Mr. 10m/s is your name and that’s how you shall be called!! Last name 256 buffer
#42
If you've measured the round trip latency of the path (which is easy to do), then just add a delay line with the additional latency desired.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
#43
I hear you though and i understand that, at least when playing VIs, it could be placebo and being "spoiled" in modern times vs old digital pianos. But whatever it is, i am so used to it.. I really got addicted to low latency from creamware days, that's when it all started for me with regards to digital audio.. Also, at the very same time, in the studio, we had a pro tools mix cube and G3 mac.. so all i had was ultra low latency both at work and at home.. All my hardware synths were being monitored through avid tdm hardware using logic as a front end (ah those were the days lol!). it felt FAST. It WAS fast. I can literally feel the difference now between 32 and 64, and 64 and 128.. i kid you not.. but sure, if i wasn't worried about monitoring issues, then i could eventually get used to key playing latency. Also note, i am dealing with tons of midi hardware.. and this problem has surfaced for me due to apollo console latency.. at 8MS.. since pro tools can not, of course, nor any DAW, compensate what's going through apollo when playing live, alongside what is playing back in pro tools (ie audio tracks and vi).. the hardware through console and the software through PT are 8ms out of time with each other and it is really obvious. This is why i wanted to go lower.. but not only that.. with HDX PT can compensate the live signals anyway to be sample accurate with the internal PT stuff playing back.. it's just a case of money at this stage. If i had 25k lying around, i would be at avid dealer today, salivating. This is why i needed to ask all this stuff, to know whether it was worth the pain of selling all my apollo stuff and taking a loan out for HDX for the difference :)
- Apple Mac Studio M2 Ultra/64gb/UA Apollo x 3+Adat x 3/UAD Satellite x 3/OS 14.41/PT 2024.3/Nuendo 13/LogicX |
#44
If you can feel the difference between 32 and 64 buffer, then perhaps shelling out for HDX will be worth it...
#45
At least Avid is living in the real world, with the pricing structure for the new HDX Cards.
$3000 isn’t a bad deal.
#46
If it was 4k here which is a correct conversion, i'd buy 2 now.
#47
Where i can definitely feel it is 32 to 128. 32 literally feels that as the keyboard key makes contact, the sound is heard instantly. Unfortunately, the cpu usage is ridiculous which is why i settled on 128 in PT when i do 44 or 48K.. 128 seems to have most benefits performance vs latency wise. I can be playing a korg kadget aax synth at 128 buffer, just some drums, and it is using 3% cpu when armed live.. drop it to 64 and it jumps to 50%, 32 to 70. The difference in cpu is so great when you go under 128, on mac at least, that it's just not worth it. On windows daw's in general, because you can disable speedstep in bios and everything related to it, it's a lot more stable at low latencies. I used to be really into performance testing as a side hobby and i've tested every major DAW on both mac and windows, as well as windows via bootcamp on the same mac, and windows always thrashes mac for number of plugins using same interface and same cpu.
MIDI recorded latency after playing with no latency | genebackmusic | Pro Tools 12 | 8 | 01-19-2016 02:36 PM |
Automation latency when using plugins that have long latency | pyrodave | Pro Tools 11 | 2 | 01-27-2014 11:22 AM |
omni/native latency vs mbox pro latency | chrisdee | Pro Tools HDX & HD Native Systems (Win) | 34 | 03-30-2012 07:24 AM |
Latency Issues - changing latency has no effect | Kippa-Dee | Pro Tools M-Powered (Win) | 1 | 07-15-2010 08:39 PM |
Unity DS-1 and Latency... Anyone else feel the latency makes the Plugin unusable? | Mt.Everest | Pro Tools TDM Systems (Mac) | 7 | 08-26-2001 04:53 PM |
