Re: Brand new automation/ish problem
I've had this. I think it's a bug, fortunately rare in my case. An audio channel's volume or pan jumps to a random position even with automation turned to "off" on the channel. There is NO way a fader or pan should move on an audio track if auto is set to "off".
It happened with pan on a mono track and volume on another track on Monday. WHATEVER I did, the pan would jump to +66. I looked at the Pan parameter in the automation lane and it was completely blank, regardless of whether automation was in read/write/off etc. I couldn't manually draw in pan automation, there was NO pan "line" in the lane to draw break points on! Same thing with the track view set to pan. I tried deleting "all" or "pan" automation for the channel yet still the pan was stuck and would jump to +66 when I hit play. I couldn't write new pan automation to the channel in any mode. I created a new track, copied the clips/plug ins from the stuck pan track across and the pan worked as normal again. There's something screwy going on here.
Dave Marsden UK |
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
There was no fader or pan movement just a difference in volume. Im getting some love today from my system so Iv been trying some stuff and its working for now but I had to put a limiter on those tracks unfortunately. Limiting starts at ten times the ratio over threshold . So at what ratio does it become brick wall limiting. |
Yes I am using a control surface, an Avid C|24. That connects via ethernet so it's not a MIDI issue. Interesting that phatbeatstudio is also using similar control surface. @StewartFang Next time it happens to me I'll try turning the C|24 off.
Dave Marsden UK |
#16
Since the C|24 doesn't really offer much "configurability", you're probably correct about it not being an issue. But let me offer something in case a noob should stumble across this thread...and note that this is a very simplified discussion... Did you know that you can send MIDI over the electrical wiring in your house (DON'T DO THIS!) or over a couple of coat hangers? In fact, you can send/receive MIDI over any pair of wires (or even wirelessly) as long as you have the right transceivers at either end. MIDI, as the term is most often used today, is simply a protocol, or an agreement as to what "language" two (or more) devices will use to communicate. Think of it this way...if both of us are speaking English, it doesn't matter if we are talking over a landline, a cell phone, or via Skype. While, IIUC, the 9-pin DIN MIDI cable is specified in the MIDI standard as a medium for transmitting MIDI data, it is not the only medium that can be used. In fact, I how imagine that most MIDI data is now carried over the USB cables that now connect "music" keyboards to computers. So it is with control surfaces...the type of cable (or medium) used doesn't necessarily dictate whether or not MIDI (or protocol) us being carried over it. So just because a control surface connects with an ethernet cable doesn't mean the protocol isn't MIDI...
#17
If there is no MIDI in the songs you downloaded what exactly did you download from the internet? I doubt anyone puts out .ptf or .ptx sessions for free download on the net except in a learning situation.
Have you done ANY of the things I've talked about in my previous post? You have SO many problems going on that a start from zero would be the best bet. |
#18
It has passed 2 out of 6 times with 4 fails. I honestly only remember it passing once to my memory Im just giving it a credit. It says something like a 192k 96k unable to perform. Something like that. 2 I don't clock externally . I don't have a external clock. 3 There were a few times I tried to play before the files loaded. 4 If cache is green that is good to go isn't it. I really don't do much automation at all. Some tom fills, guitar to and from different sections . A lot of fade ins and outs. and more recently a bunch of clip gain, But not much automation. My system seems to be working great today and the little I used it yesterday. Except it keeps opening without all the tracks. I don't do anything fancy . Because of the issues I get I try as hard as I can to not mess around with it. If it aint broke don't fix it. Its working now for some reason thats all that matters to me . I just wish I knew more about this type of stuff so I could fix more issues on my own. |
#19
I went through hell about 10 years ago. Damaged audio files, sync problems, software issues, etc. It turned out to be the G3 Mac that started to "dissolve". After a glowing phone call to my dealer, they sent me a new G4 instead. Problem solved!
#20
Then while the card is at Avid completely wipe clean your drives, reload whatever version of OSX you're using, get all your ram from the same source (OWC is great), re-load PT and any plugins you're using and try some basic sessions while you wait for the card to come back. Yes - you can use 10HD without the HDX card using whatever basic sound I/O you have on your Mac; it'll even have many of the features of 10HD but without dsp and a couple of other things (basically just like regular PT with the CPTK). And do NOT use a Time Machine backup or Migration Assassin (Assistant) to bring stuff back into your Mac. |
Automation on brand new audio track? stupid | anackman | macOS | 2 | 10-23-2012 05:37 PM |
Pro Tools 8LE Freezing...brand new iMac! What is the problem?!?! | DJM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 20 | 09-01-2011 04:50 PM |
Screen Problem with brand new profile | JCollee | VENUE Live Sound Systems | 4 | 12-24-2010 12:28 PM |
brand new problem | supafuzz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-06-2009 08:06 PM |
6.7 is crashing my brand new dual core PROBLEM SOLVED! | supafuzz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-07-2007 03:49 PM |
