Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 07-23-2010, 12:08 PM
timeey timeey is offline
Default DI-boxes!
Hi.
I need a DI-box that let's me run my amp into the Mbox 2, and then again be monitored with my KRK RP5's.
I thought i had this down, but now i am really confused again.
I have been looking at these DI-boxes for my purposes:
- Samson S-Direct: http://www.nantelmusique.qc.ca/repos...t/s-direct.jpg
- Radial Pro RMP:http://cachepe.samedaymusic.com/medi...75527d2a8a.jpg
- Radial Pro DI: http://www.bassemporium.com/images_p...adialprodi.jpg
As far as i thought, all of them do the same job as i want them to.
Until i read about the Pro RMP. it talks about reversed signals, and correct me if i am wrong, it sends prerecorded music back out so you can put your amp sounds on your recording?
I don't get this..
What i need is a DI-box that let's me run my amp into my Mbox 2, and just record.. simple as that really :P
Old 07-23-2010, 01:05 PM
TCM's Avatar
TCM TCM is offline
Default Re: DI-boxes!
Any DI-box for running a signal to your interface is good.
I have got a this setup:
guitar--> Radial JDI -->002R
.........................!--> guit amp
works like a charm.
002R BLA mod and Mbox mini 2, PT 11.3.2,
HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive
Old 07-23-2010, 01:14 PM
Right.
DI boxes.. i guess the RMP is a reamp though.. not used for the same thing.
Can't record thorugh a reamp, you can only reamp prerecorded tracks.
Old 07-26-2010, 10:28 AM
But what if i buy an active DI-box that requires 48 phantom power,
can i use the 48 phantom power switch on the mbox 2 for this?
I find it a bit strange that the guitar signal will run through an XLR cable and into the Mic-input of the mbox 2..
Old 07-26-2010, 11:44 AM
nst7 nst7 is offline
It's not strange at all, that's what DI's have been designed to do since they were invented. Whether it's an active box or not, it still needs to go through a preamp. Though there are some DI boxes with built in preamps, like the Avalon U5, which can go directly to a line in.
Old 07-26-2010, 12:11 PM
Craig F Craig F is offline
Originally Posted by timeey View Post
Hi.
I don't get this..
the RMP is not a DI it is a re-amp or DI in reverse (most passive DIs can do this to some degree)
I would take the Radial DI over the Samson
if I may ask, what's wrong w/ the DI in (may be labeled Instrument) your Mbox for getting started
there are better DIs but for getting started....
Thank you,
Craig
Old 07-27-2010, 07:27 AM
flommer flommer is offline
Well, this could mean a couple different things:
The amp has a recording output (or some kind of preamp output)
OR
You want to record from the speaker output. We are talking about a guitar amp here presumably?
In either case, you don't need a DI.
Case 1, the output is already going to be line level...
Case 2, you want a device that loads the amp like a speaker, yet outputs line level. (You can actually damage your amp and/or anything you attach it to if you do this incorrectly) Look these up:
THD Hotplate
Marshall Power Brake
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Summing boxes...no thanks! David Schober Pro Tools TDM Systems (Mac) 60 10-12-2006 02:13 PM
24 bit A/D boxes bigfrog General Discussion 2 02-26-2004 08:08 AM
NEED HELP ASAP!! GFI boxes andyo Pro Tools TDM Systems (Mac) 3 07-24-2003 09:59 AM
Does anyone know about summing boxes steve0916 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-07-2002 12:50 AM
Isolation boxes gargoyle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-05-2001 07:04 PM
