Eleven Rack Drivers Windows 10
Anyone having installed Eleven Rack on a Windows 10 machine? I did, get blue screen all the time!!! Idea when drivers for W10 zill be available? Thanks Jonathan |
Re: Eleven Rack Drivers Windows 10
I'm using Windows 10 with the Eleven Rack and have not had any issues, but Windows 10 is not approved by Avid. There is no timeline for approval.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Has anyone tried running Pro Tools 10 on Windows 10?
Yes... no bluescreen here. I also run Mbox pro and a GP10 as interfaces with PT12.1 with no issues. I did go to avids webpage to make sure that I had up to date drivers n firmware for the Eleven Rack. There is some information there on getting blue screens that if I recall correctly uniformly instructed the users to run windows update. Hope that helps.
I just remembered something worthwhile of passing on... if you update to windows 10.. don't forget to go in and check your ProTools optimization settings. I found that it retained most of them but it did change some power management settings on USB. Not all... just some, so I had to go in and deselect a few.
Dave |
Hi, does anybody on windows 10 have troubles with the eleven rack editor, in mi case it shows up the window but immediately send an trouble and i need to close up
Yes, in my case only about half the time though. To be clear, the eleven rack editor window comes up and is initially populated as one would expect, if I try to make adjustments the entire window goes white. As far as I can tell thus far, I can still make adjustments using the physical face of the eleven rack that are reflected within the protools session. Not yet had the time to chase this down any further.
Hello, I know that Windows 10 is not recommanded by AVID but here is my problem:
I have two computers, one desktop (ACER I3) and one laptop (ASUS I7), both on Windows 10. I have no problem with my desktop but I can't use Eleven Rack Editor with my laptop. Once Editor is on, it loads the Rack parameters and then, the windows stays blank. It happens everytime I try to launch it, even after a reboot. When my laptop was on Windows 8.1, I had no problem. Has anyone ever had this issue? Is there anything I can do to fix it? Thanks a lot. |
Eleven Rack 1.1.1 Drivers & Mountain Lion | MrBig1964 | Eleven Rack | 0 | 11-03-2012 08:48 AM |
Mountain Lion compatible drivers for 3rd gen Mboxes, Eleven Rack, C400 & C600 | Avid | Technical Alerts | 0 | 09-25-2012 06:44 PM |
Eleven Rack Problems with USB e Drivers | DaniTo | Eleven Rack | 1 | 06-23-2012 06:05 PM |
How/Where are my eleven rack drivers... | leblanc74 | Eleven Rack | 19 | 03-31-2011 07:35 PM |
Where to find Audio Drivers for Eleven Rack | 00011011 | Eleven Rack | 6 | 10-12-2010 08:57 PM |
