Old 11-11-2013, 11:57 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Offline Bounce
Like a lot of folks, I really do like the offline bounce options. What I wish we could do, though, is do an offline bounce that would allow us to save each track of the mix separately (in either stereo or mono) all at once. One bounce...all multiple tracks separately out. That would save a lot of time!
If it can be bounced that way, then I'm not seeing how to do it in the manual.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Dell XPS 435T/9000 Win-10 Pro 24gig RAM
IntelCore i7 CPU 920@2.67GHz
Pro Tools 2019.10
Focusrite Scarlett 8i6
Old 11-11-2013, 12:05 PM
Drew Mazurek's Avatar
Default Re: Online Bounce
PTHD allows up to 16 paths. Mono, Stereo, Surround.
http://www.avidblogs.com/pro-tools-1...ve-processing/
www.drewmazurek.com
Old 11-12-2013, 07:21 AM
DonaldM's Avatar
Meant to call this thread "offline" bounce..oops! Anyway, I knew I had seen this feature somewhere...forgot it was for HD users only! Oh well...
Pro Tools 2019.10
Old 11-12-2013, 07:53 AM
bakerja bakerja is offline
Default Re: Offline Bounce
Not too difficult to achieve via solo. Just solo the track you want to bounce and bounce it. Move to the next track...
Shouldn't take too long
27" iMac OS 10.8.5
32 gb ram, Dual monitor
USB3 2TB audio drive
USB3 2TB sample drive
M-Audio projectmix I/O w/Behringer ADA8000
Bakerplace.net A place for Audio/Video Post Production.
Old 11-12-2013, 11:14 AM
DonaldM's Avatar
Yeah, I know...that's what I've been doing. Would be faster all at once though! C'est la vie!
Pro Tools 2019.10
Old 11-17-2013, 05:50 PM
Table Syrup Records's Avatar
Table Syrup Records Table Syrup Records is offline
I second this -
I am currently working on a sound library of around 275 compositions - first round of thousands, and I need to mix all of them, and bounce the entire track and just the instrumental, and all stems, as WAV and MP3..... granted 11(HD) makes this much faster with offline bounce, I could still use a setting that would let me bounce each track separately
Would be a huge time save. IdeaScale? hmmmm
PT has come a long way, but this is still a standard of other softwares (such as Cakewalks Sonar for example, and I'm sure others)
Shorty: Table Syrup Records
Mac Pro 5,1 3.33 GHz Hex, 32GB
EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23"
OSX Sierra
Pro Tools HD 11.2.2
Waves IOS, IOX, STG2412
Extreme Server (x2)
Logic Pro X, DSP Quattro, Final Cut Pro X
Waves Mercury+SSL+AbbeyRoads
Trident S65 with embedded US-2400
Live:
2012 Mac Mini, Dual SSD, i7 2.4, 16GB
Win 10, OSX Sierra
LV1, MRSG
Hardware from above (same gear)
Dual Dell P2418HT Touch Screens
Waves Icon X (x2), M, with Screens
Custom enclosure
Old 11-17-2013, 08:56 PM
Eric Lambert's Avatar
If bouncing all of this simultaneously how would you achieve the proper isolation of reverbs, delays, etc? For example, when creating a lead vocal split you only want the reverb to process the vocal (which would then be included in that lead vocal split), but if bouncing multiple splits at once then your reverb will also be processing, and therefore including, all of those tracks which are sent to it at once. Same with delays and other things in a send/return scenario. So the lead vocal split would contain reverb from the background vocals, and vice versa, and on and on.
Offline bounce bug ? deardaddy Pro Tools 11 20 12-28-2016 02:43 PM
offline bounce different than realtime bounce grant howarth Pro Tools 11 8 12-08-2013 09:29 PM
OK, but seriously, OFFLINE BOUNCE! Kris75 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 120 04-09-2013 06:55 AM
Offline bounce spyfly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-21-2007 12:50 PM
Offline Bounce? bboiii 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-12-2005 02:38 PM
