Old 02-10-2020, 04:26 PM
dg27's Avatar
dg27 dg27 is offline
Default Moving from 12.8.3 to 2019.12
I've been holding on to Window 7 for as long as I could (which is why I'm still on PT 12.8.3).
Next week I plan to take the plunge and move to Win 10 Pro. After that I'll install PT 2019.12.
Should I anticipate any compatibility issues with sessions created in 12.8.3?
Old 02-11-2020, 05:17 AM
Default Re: Moving from 12.8.3 to 2019.12
Other than possibly missing plugins there shouldn't be issues. Make absolutely sure you have a backup of your working system BEFORE going to Windoze 10. And disconnect that backup drive so it doesn't possibly get corrupted during the W10 install.
Old 02-11-2020, 06:50 AM
dg27's Avatar
I have installation files for all 3rd-party plugins, all very orderly in folders with license keys if applicable.
Regarding Avid-provided plugins, are there plugins that were provided in PT 12 that are not provided in the 2019 versions?
I run Acronis 3X per week on different internal and external drives, so I'm covered there.
Wouldn't have though of that--thanks. I've actually read that you should disconnect all other drives when installing W10.
Old 02-11-2020, 07:30 AM
EGS's Avatar
EGS EGS is offline
I have installation files for all 3rd-party plugins...
I suggest NOT installing those, but rather be sure to install the latest/greatest versions of all plugs. Typically, just go to each company's site and DL the latest versions. The latest AVID plugs are also available to DL. A few months ago I updated Win 7 to 10, got the current PTools, and all current plug versions ---> works!!!
Desktop: PT 2020.5 / Win 10 / GIGABYTE GA-X58A-UD3R / i7 hex 3.9GHz / 32GB / Focusrite LS56
Laptop: PT 2020.3 / Win 10 / HP ProBook / i7 quad / U-PHORIA UMC1820
Legacy: PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI001
Click for demo
Old 02-11-2020, 07:32 AM
It should be a no-brainer to download fresh plugin installers
Old 02-11-2020, 08:06 AM
dg27's Avatar
Thanks for the plugin suggestions.
I've got a lot of downloading to do...
Old 02-11-2020, 07:56 PM
enfamale enfamale is offline
I made the move from 7 to 10 and had a smooth transition so far and didn't lose anything. Im still using 12.5 right now thinking of going to 2019 but don't know about my older 12.5 sessions playing in 2019.
Old 02-11-2020, 08:05 PM
dg27's Avatar
Hmmm..I wonder whether I should go from 7 to 10 with 12.8.3 then move to 2019.12 later.
Downside to that is I'd have to reinstall all the plugins all over again.
Was really hoping to do it in one fell swoop.
Old 02-12-2020, 05:25 AM
Nothing to worry about. The older .ptf session format opens just fine in PT10 and later, and .ptx format introduced in 10.0.0 is still current. Going for a newer version is not a problem.
Old 02-12-2020, 06:12 AM
kw88keys kw88keys is offline
I did the same as you - updated to W10 and from 12.4 to 2019.12.
The only glitch was Windows 10 populated my bios with a floppy drive.
That caused a 6 second delay in record and playback-after-record. Once I went into bios and removed (not disabled) the floppy all went well.
Workspace Borked 2019.10 and 2019.12 KMcK Pro Tools 2019 0 01-17-2020 02:09 PM
2019 iMac vs 2019 Mac Pro Peterjk Pro Tools HDX & HD Native Systems (Mac) 7 01-14-2020 12:23 AM
Install pro tools 2019.10 over 2019.6? Clarkston Guy Pro Tools 2019 6 11-01-2019 08:12 AM
Updating from 2019 .5 to 2019.6? ihate100bees Pro Tools 2019 13 07-04-2019 08:30 AM
