Old 11-04-2008, 08:45 AM
dendee dendee is offline
Default "undo" function and history on 1 track?
not sure if this exists...having a history giving the ability to "undo" changes on an individual track only. say you spend a day tweaking plugs etc, then want to refer to a previous approach that you had going on one track. is there a chronological history per track, so you could go back and click on a particular setup in time to restore the plugs and settings that were used on the one track? i know, save the mix but it would be useful to have multiple undo's at the track level.
Old 11-04-2008, 09:55 AM
Bobby Peru Bobby Peru is offline
Default Re: "undo" function and history on 1 track?
There is if you have Autosave engaged. I have Autosave set to keep the last 99 saves - once every 3 minutes. I ended up setting it to 3 minutes, because as silly as it seems, 5 minutes held too much work for me.
Bobby Peru
Milwaukee, WI
Undo Issue - "Change Control Value: Automation Warning" admix Post - Surround - Video 11 09-20-2013 08:08 PM
UNDO: Why do i have multiple "Change Control value" before undoing what i need? EDurney macOS 5 01-10-2012 08:55 PM
Undo history deletes when a track is deleted seafra macOS 0 10-28-2011 10:34 AM
How i can asign to my 01v "undo" function? mmestudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-26-2003 07:30 PM
If I "Remove Unused Regions" after "Consolidate", track won't play? el biciclista Pro Tools TDM Systems (Mac) 10 04-02-2003 10:17 AM
