Clips move oddity
Hi all,
I'll make this quick. upgraded PTs to 2018.7 on a Win 7Pro SP1 64 comp over previous install all went fine. On trying to trim or move a clip in edit mode the clip jumps halfway between its track and the one below. (see pix attached) but it goes back after letting go of the mouse. it does the move or trim fine but it is annoying. any help will be great. BTW: Nvidia geforse GTX 1050 TI graphics card, Intel i7-4770k cpu, 32 gb ram, 64 bit OS |
Re: Clips move oddity
2018.7 is not supported on Windows 7
Chances are this has to do with Windows Aero graphics. Try switching your desktop to using or not using Aero (whichever is the opposite of what you have on now)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 Last edited by BScout; 08-31-2018 at 01:18 AM. |
I have this too. The start of noticeable incompatability with Win 7.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring. Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n |
If you disable Clip transparency it goes away... but clip transparency is too good to be disabled and still be happy!!
I have a Nvidia 1050 too... maybe it's related.. Migrating to windows 10 is a pain I wanted to avoid as long as possible...
PC i79700K 4.8Ghz 32Gb ram Nvidia1050 Win 10 64 SSL MX4 |
BScout, tied disabling Win aroe no difference.
Prabha, haven't tried turning off transparency, thou I agree it's to good to turn off. may have to bite the bullet and get Win 10 I wonder if anyone on Win 10 is experiencing this??? |
I get this also on Windows 7. Would be very interesting to know if this is present on Windows 10. Any Windows 10 users want to respond? Thanks.
I have seen this happen on a Windows 10 system, but with an AMD GPU. In this case, I thought it was the AMD drivers that caused it. It started just after the system was upgraded to 2018.7.
I have always found NVidia GPUs and drivers to be more stable in this respect. I use NVidia GPUs on both my Windows systems (and indeed my Mac) and am not getting this issue with 2018.7. Have you tried turning off GPU acceleration in the Pro Tools prefs? If this solves it, it could point to something being broken in 2018.7’s GPU handling. Have you updated your NVidia drivers to the latest version? To the OP - "migrating" to Win10Pro is nothing to be frightened of, but what I would suggest is to not "upgrade" your OS, but to do a new install on a fresh system drive from scratch. It is now a very quick process - I have found Win10Pro installs from scratch to take no longer than 10 minutes. If you use the Microsoft Media Creation Tool on their website to make a bootable USB drive, it compiles the very latest version of Win10, with all the necessary updated drivers and all the latest features, so you don't then have to spend hours getting Windows up to date after install, like you have to with Win7. I've found that upgrades in situ from Win7 or 8 to Windows 10 can literally take days and result in having to re-install key software anyway, so you might as well do a fresh install. You will notice an instant improvement in boot speed and overall system efficiency. While you’re at it, if you’re not already, I would thoroughly recommend upgrading your system drive to an SSD as well. As far as legacy software support goes, my wife is still using Win XP audio software quite happily on her Win10 system. The only time I've ever had issues was when I went from 32bit Win XP to 64bit Win7 and some hardware manufacturers never updated their drivers. I wouldn't think you'd have this issue, as you're already on a 64bit OS. I would also highly recommend installing Win10Pro. If you're put off by the three-figure price for buying this OS, take a look around the internet for an OEM licence key - you can pick them up for £20. The only difference with an OEM key is that it is locked to the hardware you install it on, so if you upgrade your core hardware (CPU), you might need to buy another OEM key.
Pro Tools Utimate 2018.7, on - i7 5820k 6 x 4GHz (12 threads), 16GB DDR4, Win 10 Pro, BM Mini Monitor PCIe, GTX 660Ti 2GB; Dell Laptop, i7 4x3.6GHz (8 threads ), 16GB DDR4, Win 10 Pro, GTX1060MaxQ 6GB; "Plan B" - i7 6700k, 4 x 3.4GHz, 16GB DDR4, Sierra, AJA Kona LHi, GTX 1050Ti 4GB. RME FireFace802 + ARC, RME Babyface Avid D-Command, Artist Control, V-Control, Korg MicroKontrol 7.1.2 Presonus Monitors |
Thanks very much 8dB.co.uk, A very thorough and helpful reply!
I have decided to just go back to 2018.4 for now. It worked fine and did not have this issue with my system. Someday when I feel motivated I will update to Windows 10 but 7 is just too comfortable. Kent |
Thanks 8db.co.uk for the reply, I'm not sure of how to turn off GPU acceleration in PT unless your talking about under video prefs.? If so I tried that and no luck.
Again I may have to install Win 10 Pro. Or as Kw88keys says roll back to 2018.4 |
Like kw88keys I have gone back to 2018.4 until I change to Win 10.
How to move make meter follow clips? | amagras | Tips & Tricks | 4 | 08-16-2016 04:16 PM |
How to move all tracks/clips at one time | pforbess | Pro Tools 10 | 4 | 07-29-2016 11:26 AM |
EDIT and MOVE 'frozen' clips (Ideascale) | msuk | Pro Tools 12 | 5 | 12-30-2015 07:45 AM |
PT 8.0.4 - audio clips stuck, can't move? | magnus1225 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-03-2010 07:08 PM |
