Old 10-16-2022, 04:04 PM
Focuret Focuret is offline
Default Can we use Aux IO to have system output come from monitors when Pro Tools is running?
I used Source Nexus before. Had Source Nexus on tracks in PT and set MacOS output to Source Nexus. But now Source Nexus crashes the new version of Pro Tools. Is there a way to use Aux IO and set the system sound output to use one of all these Pro Tools Audio Bridge things?
MacBook Pro Touch Bar (15-inch, 2016 2016), 2.9 GHz Intel Core i7, 16 GB 2133 MHz LPDDR3, Radeon Pro 460 4096 MB
Intel HD Graphics 530 1536 MB | macOS Monterey | Avid HD Native Thunderbolt | Avid HD Omni | Pro Tools Ultimate | Avid Artist Control | Avid Artist Mix
Avid Artist Transport | Genelec 8351b Monitors | Genelec 7360A Subwoofer x2 | Slate Digital VMS Virtual Microphone
Old 10-16-2022, 04:15 PM
Sardi Sardi is online now
Default Re: Can we use Aux IO to have system output come from monitors when Pro Tools is runn
Yes.
You can find lots of videos to guide you through it if you’re having trouble.
But, unless you’re on an HD system, most Core Audio interfaces are multi client. I’ve been using my interface with half a dozen apps (inc. PT) running at the same time for many many years. My typical daily workflow has PT, RX and system audio running simultaneously.
Old 10-16-2022, 04:35 PM
Originally Posted by Sardi View Post
Yes.
I’m on an HD system. Avid HD Omni interface with an HD Native box. The videos I’ve seen so far doesn’t seem to work for me. I made an Aux IO in Pro Tools, made a track with the IO as the input then set the system output in macOS to the same IO and no sound.
Old 10-16-2022, 06:59 PM
Eric Lambert's Avatar
Historically, Avid hasn't made this easy for HD users. Many route digital outs from their computer into their interface, which is what we did for a few years, but that has always seemed like a silly workaround for moving digital audio around the machine.
With 2022.9 you can now have your Mac send system output to the Aux IO and create a track in PT which listens to that Aux IO. I keep one in my template. This works well. I'm not sure why you're not getting the same result but it's likely a simple tweak. Are you certain that the IO you're selecting as the Mac's output is the same as you're selecting in PT? There's not supposed to be much to it beyond connecting these two pathways.
Source Nexus is what we use(d) for post sessions but it's unreasonably expensive and now obsolete.
Old 10-16-2022, 07:36 PM
Source nexus was what I used up until this broke. Would you mind sharing how you have your aux up track set up? I have done it according to the video and set my system output but it doesn’t work. No sound.
Old 10-16-2022, 09:07 PM
its2loud its2loud is offline
Here’s a good startup breakdown for Aux IO.
https://youtu.be/D1UPXfSjiJM
What OS are you running? You need to be on at least Big Sur.
Old 10-16-2022, 09:34 PM
Monterey. I saw that video. It is just, it just doesn’t work. I cannot for the life of me understand why.
Edit: typed the wrong Mac OS version at first.
Old 10-16-2022, 09:38 PM
Mojave. I saw that video. It is just, it just doesn’t work. I cannot for the life of me understand why.
It doesn’t work because you’re running Mojave. It only works on Big Sur and higher.
Old 10-16-2022, 09:52 PM
I shoulda caught that in your signature. As mentioned above, the hurdle is your OS. You're a couple iterations behind the minimum for Aux IOs.
Old 10-16-2022, 10:42 PM
Damn it. I meant Monterey. The latest version.
SourceNexus plugin allows system sound output thru PT interface while PT is running Focuret Pro Tools HDX & HD Native Systems (Mac) 8 12-14-2016 01:25 AM
Possible to have system sound output set to HD Native while Pro Tools is running? Focuret Pro Tools HDX & HD Native Systems (Mac) 10 12-08-2016 08:20 PM
Noise on output of Fast Track Solo when running Pro Tools Express JorisG Pro Tools 10 1 08-22-2016 09:21 AM
Pro Tools Output Not Going to Monitors Waheezee macOS 1 01-18-2011 08:47 PM
Running Pro Tools LE 8 on XP and running 2 monitors JRup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 05-31-2010 07:38 PM
