Pro Tools wont boot after updating to 11.3.2
I recently instaled 11.3.2 in because TL autopan would crash pro tools if I clicked on the key input.
Now when I go to launch pro tools, this happens. And When I click "No" this happens. What is going on and what is the fix? Thanks for your help Robert |
Re: Pro Tools wont boot after updating to 11.3.2
Just guessing here, but I think if you just click Yes, then PT will start just fine. Those are probably 32 bit versions of the plugins, left over from a previous installation, and they are causing the error.
After clicking yes, i still got the same last error message.
I've un-installed 11.3.2 and installing 11.3.1 Gonna see how this works out |
So 11.3.1 works okay however I keep getting "Pro Tools is running out of CPU power" which cant be possible as its been fine before in the same session.
But I would really like 11.3.2 working. |
What version of OSX are you running? System info in your profile has everything BUT the OSX version. That being said PT11.3.2 runs no problem in OSX 10.9.5.
I'm running 10.8.5
Frantically updating all my plugins incase it's that... Any thoughts? |
If you notice and look at his Dock you'll see he also has PT10 on his system. A lot of getting PT10 and PT11 to play nice with each other is to install PT10 first and then install PT11. Going the other way around can cook up weirdness - been there/had that happen.
I have only reinstalled PT11. I haven't installed 10 after.
I just updated to 11.3.2. and it would not open at all so i'm now on 11.3.1 I'm not sure whats going on here |
deleted by me - didn't read above answer - sorry 'bout that
If you check my reply below your question you will see I said 10.8.5
Replaced 002 now Pro Tools wont boot | zames | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-11-2013 01:28 PM |
Updating to 2.8.1 .... CD won't boot on reset | Eeyore | VENUE Live Sound Systems | 2 | 06-16-2010 10:43 PM |
Pro Tools wont boot after a fresh install of windows | sammyfarr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-08-2008 09:03 PM |
Pro Tools wont boot after updating to osx 10.4.9 | sammyfarr | Pro Tools TDM Systems (Mac) | 4 | 03-20-2007 12:48 AM |
Updating Dual Boot system?? | nukmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-04-2004 07:49 PM |
