Old 12-28-2011, 03:55 PM
RickT RickT is offline
Default MBox Pro Rear Input Jack Problem - Won't work unless the plug is pulled out a bit
I have an MBox Pro unit that was working fine until just recently when I could no longer get any sound out of the rear 1/4" input jacks. Today I found out that if I pull the cable part way out of the rear jack I get signal. It's never done this before. The front jacks work fine when the cables are pushed in all the way. Anyone ever heard of this problem before? I'm at a complete loss here
Thanks,
Rick
Windows 10 - Pro Tools 2018.12.0 - Quantum 2626 - Axe-FX III
Old 12-28-2011, 04:26 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: MBox Pro Rear Input Jack Problem - Won't work unless the plug is pulled out a bi
Sounds like it might be a dry/cracked solder joint either inside the MBox or the cable itself.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 12-28-2011, 05:31 PM
I would like to agree with that except all four inputs in the back won't work unless the cable is pulled out a bit. It can't be the cable either. I've tried two others and they do the same thing and all of the cables work properly when plugged into the 1 and 2 inputs on the front of the MBox.
Old 12-29-2011, 02:23 PM
zedhed's Avatar
Is it still under warranty? sounds to me like you're going to have to get someone to look at the unit.
HD 96I/O
Old 12-29-2011, 02:37 PM
Yeah, it's only 4 months old
Old 12-29-2011, 05:20 PM
zedhed's Avatar
Well then, I would get it checked out while it's still covered by warranty.
HD 96I/O
Old 12-30-2011, 09:12 AM
Bill Denton Bill Denton is offline
Are you using a Tip/Sleeve cable, like a guitar cable, or are you using a Tip/Ring/Sleeve pro audio cable?
I believe the rear inputs are balanced, and require a Tip/Ring/Sleeve pro audio cable.
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 12-30-2011, 09:51 AM
Hey Bill, I'm just using a regular guitar cable. I'll go dig in my big box'o cables to see if I can find a Tip/Ring/Sleeve cable and see if that works. Thanks.
Old 12-30-2011, 02:07 PM
Well that didn't work either. I also don't see any mention of the ring sleeve type cable required for the back in the Mbox Pro's owners manual. There is however a toggle button on the front to switch from the front to back inputs. They don't do anything though.
I know the rear inputs worked fine before when I first bought the unit so I'm sitting on hold (30 minutes now) for an RA#.
Old 04-13-2012, 05:45 PM
shai_shaashua shai_shaashua is offline
Hi Rick,
Not sure if you are still dealing with this but anyway:
I just found out that on my Mbox Pro the wiring is wrong. as far as the mic/line and the front/rare buttons are concern, 1 controls 3, 2 controls 4, 3 controls 1 and 4 controls 2. Try playing around with these buttons. For example, to get a signal from line input 1 (1/4") the mic/line button on channel 3 needs to be engaged.
Hope it helps
Mbox 3 Headphone Jack Doesn't Work FairChild Getting Started 4 02-03-2014 01:07 AM
Mbox Rear Plug Types. TRS or TS ? storeya 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-05-2012 06:42 AM
My headphone jack has pulled apart my adapter Hotcrazyfruit Eleven Rack 13 11-11-2011 09:16 AM
MBox 3 Pro Line Input (rear) Gain Garry R 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-23-2011 03:28 PM
Mbox input jack problem Tim Glasgow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-11-2003 01:22 AM
