Old 12-03-2007, 07:46 PM
pguy pguy is offline
Default How Do I Import Midi Files?
Hi, new here. I'm very new to Pro Tools. I 've been checking out video resourses for learning before I dive in. Pro Tools seems great. I've been using Sonar for a few years.
I record only audio and work with midi for my background tracks. Can pro Tools import whole midi files and distribute each instrument on its own track, automatically like Sonar?
How do I do this?
Thanks
Old 12-05-2007, 10:17 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Re: How Do I Import Midi Files?
Yes. Go your File menu and select Import, then select MIDI. Locate the MID file you want to import and click on it within the dialog box. When the MIDI import options box pops, make the selections you want. Probably you'll just want to select "New Track" for destination. Then click OK. A Mid track will be created within PT for each track in the MID file. However, the only names you'll see in PT are MID-1, MID-2 etc. So, you'll have to route the MID track to play something you can hear to figure out which track is which, and then I'd recommend re-naming accordingly, then selecting the voices you want each to play from what ever midi gear (hardware or software) you're using to play the sounds on.
Hope that helps
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
How do I import my MPC2000 Midi files?? LaJaZ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-19-2006 11:00 AM
Can't import MIDI files... Steve@ZooWest Pro Tools TDM Systems (Mac) 4 05-14-2005 06:45 AM
Import MIDI files Issues Guibara MIDI 2 02-28-2002 09:25 AM
Import/export Midi files- Where are they? JPS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-25-2001 08:19 PM
Midi files, how do I import byrdsj MIDI 0 11-06-2001 01:27 PM
