Is there a way to make HD Native a sound output in MacOS after Omni gets unplugged?
I'm on an Intel MacBook Pro with the Omni connected via thunderbolt adapter. When the cord gets unplugged on accident and replugged, the Output is no longer HD Native. It doesn't even show it. Turning on and off the Omni doesn't do anything so I have to restart the entire damn computer to get HD Native back as an output source. This has messed be up so many times when in the middle of a meeting and something happens that gets the Omni disconnected, so I have to restart but restarting takes forever for whatever reason. Please tell me there's a fix or shortcut to restart the service without restarting the whole computer.
MacBook Pro Touch Bar (15-inch, 2016 2016), 2.9 GHz Intel Core i7, 16 GB 2133 MHz LPDDR3, Radeon Pro 460 4096 MB Intel HD Graphics 530 1536 MB | macOS Monterey | Avid HD Native Thunderbolt | Avid HD Omni | Pro Tools Ultimate | Avid Artist Control | Avid Artist Mix | Avid Artist Transport | Genelec 8351b Monitors | Genelec 7360A Subwoofer x2 | Slate Digital VMS Virtual Microphone |
Re: Is there a way to make HD Native a sound output in MacOS after Omni gets unplugge
Similar setup here, slightly newer MBPro.
I think losing the connection to your interface while PT is running will at least crash PT and possibly your entire machine. (Gotta keep the cat away from those TB cables!) If I try to launch a session and have forgotten to power up the Omni, PT just yells at me and I have to quit the app, turn on the hardware and relaunch the session. But that one doesn't require me to reboot the machine. What I have found is that sometimes after having worked on something and then quit PT, if hours later the MBPro goes to sleep, then the next time I launch that session it won't play and just throws an error. In that case I do need to restart the MBPro to get it all working properly.
2023 MacBook Pro 15,8 (M3 max) Mac OS 14.4 (Sonoma) PT 24.3.1.162 (Ultimate) TB Native + Omni at home Apogee Duet 3 on the road |
I don’t have a HD Native Thunderbolt to play with (this will have nothing specific to do with the Omni).
This is not showing up as a choice in Pro Tools playback engine and Audio/MIDI setup right? You can run through the standard HD driver tests seeing if the physical device shows up in macOS when reconnected (it should) and try force unloading/reloading the driver. See https://avidtech.my.salesforce-sites...ation-on-macOS |
If the HD Native gets unplugged, when I plug it back in, the system doesn't see it as a sound output. Pro Tools may not either, but I'm not sure. But for sure MacOS doesn't see it and I have to restart the computer.
So I'm wondering if there's a way to restart whatever service gets restarted when I restart the computer, WITHOUT restarting the compuer. Quote:
AvidAudioServer handles CoreAudio functionality. It is probably crashing when you unplug the interface.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
As LDS said it may be the AvidAudioServer, you should be doing some debugging: if Pro Tools is also not seeing the interface then it's not just an AvidAudioServer problem (and you should definitely try the driver unload/reload). You should be able to stop and restart AvidAudioServer: launchctl unload /Library/LaunchAgents/com.avid.AvidAudioServer.plist launchctl load -w /Library/LaunchAgents/com.avid.AvidAudioServer.plist |
I'd suggest bypassing the hub and using an OEM Apple Thunderbolt 3 to Thunderbolt 2 adaptor to plug your HD box directly into one of your MBPro ports. See if that allows your hardware and software to see it.
Not being snarky, but this sounds like a case of "Doc, it hurts when I go like this". Doc says, "Don't got like this" Maybe some inexpensive cable management/hold down bits or a longer TB cable?
HD Native w192s LOSING SOUND OUTPUT | mrkrnkn | Pro Tools HDX & HD Native Systems (Mac) | 0 | 03-15-2023 03:24 PM |
HD Hardware (HDX/HD Native) not detected by macOS (macOS 11 Big Sur | newstrings | Pro Tools HDX & HD Native Systems (Mac) | 6 | 01-15-2022 11:48 PM |
Pc can´t recognize the HD Native as a sound output | leomartins | Pro Tools HDX & HD Native Systems (Win) | 3 | 10-25-2017 03:39 AM |
No sound from HD Omni but output meters show signal | boxedin | Pro Tools HDX & HD Native Systems (Mac) | 10 | 01-02-2015 08:18 AM |
No sound from OMNI ALT Monitor output! | UnkleMik | Pro Tools HDX & HD Native Systems (Mac) | 4 | 11-18-2013 11:01 AM |
