Carbon with anything other than 10.15.7?
Was there a technical reason I missed in the documentation for Carbon only working with 10.15.7, or is that the only tested, supported version and other, more mature macOS versions will probably also work (like 10.13, or even Mojave)?
AVB has been supported for years and 10.13 is all that's required for PT 2020.11. |
Re: Carbon with anything other than 10.15.7?
A number of AVB updates came in Catalina such as support for 44.1/88.2/176.4 kHz as well as other important fixes. Carbon will not work well in Mojave because it doesn’t have those updates. And, we support 10.15.7 because it’s the latest Catalina version available.
Kyle Splittgerber Senior Principal Product Designer Avid Berkeley, CA |
AD > DA latencies are sub-1 ms at ALL sample rates for tracks in DSP Mode. And, the higher the sample rate the lower the latency as you'd expect. Latency figures are lower with Carbon than HDX systems. I'll look into getting exact numbers together to share.
User posts on GS are listing it at 0.75ms RTL at 48kHz, and 0.4ms RTL at 96kHz.
Extremely low latency. How closely do those numbers match yours, Kyle? |
Sounds very close. But, I want to get the exact figures before I confirm anything. And, I'll share that info as soon as I have it. Thanks for your patience.
Thank you, Kyle.
Bump for Kyle.
just what i was looking for |
Questions on Carbon | Armando | Pro Tools | Carbon | 13 | 07-16-2021 11:40 AM |
Pro Tools | Carbon | Avid | Technical Alerts | 0 | 11-12-2020 03:14 PM |
Carbon or Cocoa? | Audiofarm | Pro Tools 9 | 4 | 07-02-2011 02:40 PM |
