DSP Power for SoundDesigner II
Hi folks,
as I still use SoundDesigner II for some Jurassic Park synthmonsters: Which is the most powerful hardware regarding DSP power for SDII? Goal is to run SDII with plugins, but an Audiomedia II or III ( I have both) hasn't got much DSP power, e.g. for chaining Waves plugs. Best would be Nubus-Hardware, but also hints for PCI are welcome! |
Re: DSP Power for SoundDesigner II
I think, but don't quote me on this, you could run the last version of SDII with Pro Tools III hardware. Not sure if that included the PCI version of PTIII or not.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
PT III PCI was indeed the last TDM hardware to support SD II, however only Nubus hardware would support plugins in SD II, and there was no performance benefit with TDM (PT III), AM III hardware works the same.
Thanks a lot!
So an Audiomedia is already the top regarding DSP power for SDII plugins? |
That's the way I remember it, the plugins in SD II work like an AudioSuite one if I remember correctly, so TDM Isn't used or needed, again any PCI hardware will not support the use of plugins in SD II.
Thanks a lot guys!
Future of SoundDesigner II | Matthias Allgayer | Digidesign Hardware & Software | 109 | 07-16-2002 03:23 AM |
SoundDesigner II files.... | Daniel_Isaiah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-13-2002 06:52 AM |
SoundDesigner and G4 AGP | cameleon | Digidesign Hardware & Software | 11 | 06-15-2000 11:31 AM |
SoundDesigner w/001? | Fredrics | Digidesign Hardware & Software | 3 | 02-06-2000 12:57 AM |
Sounddesigner for CD burning? | tintom | Digidesign Hardware & Software | 2 | 04-13-1998 12:06 AM |
