Artist Control - Touchscreen changes color of buttons
Hello,
I have a problem with coloring the touchscreen buttons. It seems that the buttons for the surface and the soft keys changing it´s colors to more pale colors suddenly. Some colors are completely wrong from what i have chosen. Strange behaviour: If I hold down shift and use a programmed home button (the buttons call page 1 for the softkeys and the surface), the colors will be completely different.... Is there a possibility to reset the color coding or reset the display to show the colors correctly? I´m using the newest 3.6 Eucon Software, but it was the same on 3.5. Best Stefan |
Re: Artist Control - Touchscreen changes color of buttons
No one has an idea?
Can you post a picture, sounds like a screen issue.
Here are two screens (sorry for the pure quality from my handy)
Screen Artist Mix shows the first surface page of my programmed Artist Control. Look especially at the "Mixer/Lower Zone" and "Undo/Redo" buttons. They are different colors. Screen Eucon Software shows my configuration in the eucon software 3.6 on windows 10. The 4 buttons are all the same color and also in the xml file, they have equal color information codes. But the strange is, when I use the shift button and navigate on the softkeys pages (not the surface pages) the surface pages change colours. |
I think it´s a software bug, cause on the first install of the eucon software all shown completely right. After a eucon crash after closing cubase it´s like now. :/
I think what you are seeing is the multi states of these buttons. They change color depending on what their status is. For instance if there is something to undo it will change color to indicate that.
The OP is absolutely correct. I reported this problem a while back. Mine behaves exactly the same way. If you navigate to another page of soft buttons and hit the shift and home, they will be the color you programmed. If you step to them from another page they will ALL be dimmer. Annoying.
Timothy Ripley Composer, engineer, musician ripcurrentmedia.com [SIZE="1"]Mac Pro (Late 2013) 3.5 GHz 6-Core Intel Xeon E5, 32 GB 1866 MHz DDR3 AMD FirePro D500 3072 MB, Dual 4Tb Thunderbolt G Drives Acer B326HUL 32" 2560 X 1440, VIZIO video monitor Mojave 10.114.6, Pro Tools 20.3.0.163 Digital Performer 10.11, MOTU 1248 (Thunderbolt), MOTU 2408 MkII (x2), MOTU MTP AV USB (x2) |
I'll take a second look....
Yep, see this here now and have logged a bug, thanks
Still happening in 3.61.
Artist Control - Touchscreen buttons white overlay | ChrisSnyder | Artist Series | 3 | 12-19-2016 01:06 PM |
Can you change the color of buttons on the mc? | Brandonx1 | Artist Series | 7 | 11-26-2014 08:21 AM |
Feature Request: Color selection improvement for artist control | robertg | Artist Series | 0 | 12-19-2013 03:06 PM |
control buttons that light up/change color | jesse p | Artist Series | 1 | 11-02-2011 12:22 PM |
How to change fonts on all buttons (Artist/MC Control) | crustn | Artist Series | 2 | 09-22-2011 04:40 AM |
