Old 02-13-2003, 04:28 PM
Gio Mix Gio Mix is offline
Default PT 5.3.1 and Waves plugins Bug?
Hi there,
I'm running PT 5.3.1 and Waves 3.6 and I've noticed that if I have a plug in open and I need to nudge a region around using the + and - keys, instead of moving the regions it highligts an input field. On R compressor it tries to set a value on the compressor output.
I've also made sure the edit window is active, and it still does it.
The only way around is to close the plugin window, do my nudging and then opening it again.
Has anyone seen this?
Any tips?
Ciao
Gio
Old 02-13-2003, 05:28 PM
bullyboy bullyboy is offline
Default Re: PT 5.3.1 and Waves plugins Bug?
seen it,......you're not alone,.....
i think waves monopolizes the commands,...
not to worry,....
Old 02-13-2003, 07:11 PM
phenom phenom is offline
Definitely seen it ...and it is a pain. When Ren Compressor is open, can't use the locate marker function on the keyboard. Can screw with your production flow.
Old 02-13-2003, 09:49 PM
digiengineer digiengineer is offline
Man...I'm glad I'm not the only one to see this!
Bryan Jackson
Independent Audio Systems Engineer
Burbank,CA / Las Vegas, NV
Old 02-14-2003, 03:52 AM
N-G-NEER N-G-NEER is offline
It has crashed my Mac sys a few times like that going back to 5.3. I think as the other gent said it appears that Waves monopolizes the comands or the key strokes
Old 02-14-2003, 09:42 AM
soundlife2 soundlife2 is offline
This has definitely been an issue with Waves all the way back to Waves 2.8.1.
Absolutely....Waves monopolizes the keyboard while the plug-ins are open. However, there is a way around this annoyance:
When you have completed inputing your values in the Waves plugin, instead of hitting the ENTER key, hit the RETURN key. This releases the keyboard focus on the Waves plugin back to ProTools.
Yes...this is a workaround but it definitely does help.
Cheers
.: phil kovats
audio director
naughty dog
Old 02-14-2003, 10:16 AM
parak parak is offline
I think that if you tap the ESC key it will take you out of Waves text fields and Pro Tools regains keyboard focus. Just gotta remember to do it after every adjustment you make in Waves.
Old 02-14-2003, 11:11 AM
iank iank is offline
This happens to me as well,it always takes me a couple of seconds to figure out what was wrong. I close the plugin window now after I'm done with it. I didn't know it was a bug, I just figured I was doing something wrong!
Old 02-14-2003, 01:47 PM
Marcus Acker Marcus Acker is offline
When i have metaflanger(waves bundle plug ins) active...MY track plays, but stops until i put no insert on the track..ne-one seen this? Also...how do you make a new topic on here?
Old 02-18-2003, 08:55 AM
kid pro kid pro is offline
Go to the top or bottom of the web page and click "new topic".
I'll have to try the return and esc key tricks, thanks!
-kid pro
FS - Waves plugins, AVID plugins Rosco1969 Buy & Sell 12 03-11-2014 11:56 AM
Waves Plugins crandallwarren Buy & Sell 1 03-21-2013 07:39 AM
FS : Plugins alliance, avid, flux, waves plugins, blastwave sound library Roll Buy & Sell 5 03-11-2013 06:20 AM
Waves Plugins from LE and PT 9? givingbacksmiles macOS 4 01-19-2011 04:48 PM
WAVES Plugins gone???? shanabit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-03-2006 06:09 PM
