XPand wont install on win xp
Hi Xpand wont install. After a considerable amount of time I get the message "CRC fault, cycle redundancy check". I reinstalled PT M powered 7.1 but same thing happens. HELP!!
Re: XPand wont install on win xp
It seems a CRC fault is because of an error while transferring data, probably from the CD rom to the Hard Drive.
See if you can copy the files from the disc to a folder on your hard drive and run the installer from there. You might just have a bad disc. EDIT: I tried it and it won't install from my hard drive. You might see if you can get a relacement disc if you don't find another solution. |
Strange thing is that it installed perfectly on my stationary old p4 pc, but this is happening when installing on my lap, a brand new asus s5a, which by the way seems to run PT much more smoothly than the old p4 especially when it comes to redrawing windows in PT.
I can try to get a new disc, but since it nstalled fine on the p4 I suspect something else is wrong. /yours Frans Mossberg |
Pro Tools 10.3.2 wont even install! After clean windows 7 install!!! | shamanrock | Windows | 13 | 12-27-2012 04:39 PM |
Hybrid/Xpand wont play? | 6figgas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 09-04-2007 01:58 PM |
HELP!!! new Xpand disc wont work!!! | Skyflash | Virtual Instruments | 0 | 07-26-2006 08:08 AM |
PTF wont install itself when I run the install program | Tarnished | Digidesign Hardware & Software | 0 | 10-23-2001 04:32 PM |
