Old 01-27-2018, 05:25 PM
Mr.O Mr.O is offline
Default Midi instrument delay compensation
anybody can tell, if Midi track, Midi Input and/or Midi Output delay compensation is implemented in PT 2018.1 finally?
thanks
Mr.O
Old 01-27-2018, 09:53 PM
TNM TNM is offline
Default Re: Midi instrument delay compensation
Originally Posted by Mr.O View Post
thanks
Mr.O
there has been sample offset for every single external midi track for ages now.. this is the only daw i know of that offers so precise.. others use ticks or samples..
or do you mean something else?
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X.
Old 01-28-2018, 07:53 AM
I mean the following scenario:
1., You use a PT session to do all your arrangement or mixes and there
can be enormous delay on the tracks because of plugin usage, which will
be compensated with Delay compensation
2., Now you want to add one more Keyboard track with a hardware synth.
Unfortunately the Miditrack in PT dosen´t get the information, that it should
also delay the Midi information to the outside world
Has this problem solved in the latest PT version?
thanks
Old 01-28-2018, 12:12 PM
YYR123's Avatar
YYR123 YYR123 is offline
thanks
I would assume it gets compensated for once it’s in PT and gets sent out of an actual send.
But I can’t remember off the top of my head.
Daniel
Old 01-28-2018, 12:36 PM
TNM TNM is offline
thanks
i think you are maybe having some large latent plugin on your master or something, and are having a delay when you press your keyboard to when you hear it in pro tools? You have the external midi being monitored in a pro tools input yes?
If i am correct, and you are using large latent plugins somewhere, this is normal for any DAW.
otherwise, once again i just do not understand your question.
i am using massive outboard synth setups here with uad effects galore in protools, i.e lots of plugin latency, and everything is compensated correctly when i record and playback midi of my hardware synths.
Honestly i am so confused by your post, but i want to help so i am trying to understand. Sorry.
Old 01-28-2018, 12:42 PM
YYR123's Avatar
I think you are right here....
From the manual
With Pro Tools, latency occurs as follows:
• All Pro Tools systems can have Virtual Instru- ment plug-in MIDI-to-audio latency (such as when playing a virtual instrument live and mon- itoring the instrument’s output).
• ProToolssystemshaveinput-to-outputmoni- toring latency on any record-armed tracks or Auxiliary Inputs with live inputs.
• HDXsystemshavemonitoringlatencyontracks that have one or more host-based plug-ins.
The latency amount is related to the H/W Buffer Size setting—the larger the buffer size, the greater the latency. You can reduce the amount of moni- toring latency by reducing the H/W Buffer Size set- ting. However, even at the smallest buffer size, there is still some latency.
In addition, reducing the buffer size limits the number of simultaneous audio tracks you can re- cord without encountering performance errors.
From the manual
Daniel
Old 03-26-2021, 02:10 PM
jimax jimax is offline
thanks
The only solution I found is to set the max delay compensation to ZERO on all tracks !
The way to this goal is obtain by FREEZE ALL and DEACTIVATE FX on the mix bus.
Delay compensation is a nightmare with MIDI in Pro Tools.
The other option would be to deactivate manually the delay compensation of the instrument track you are record on. Then re-activate it for playback. That's a pain. And it doeen't work if you want to punch in ! So I forgot this option.
midi global offset - midi click - delay compensation - VEPRO hanstondo Pro Tools 10 3 06-24-2020 05:17 PM
Automatic Delay Compensation - PT 12.4 - Instrument Track bug swfeathers Pro Tools 12 8 09-04-2018 09:27 AM
Instrument Tracks Delay Compensation Bug migueldgoncalves Pro Tools 12 5 06-29-2017 08:42 AM
11.2.1: Instrument Track delay compensation problem rainsong Pro Tools 11 14 08-20-2014 03:43 PM
