Moving Settings
Working in a facility with multiple S6s and the staff will bounce around various rooms depending on scheduling. The surfaces are all identical. I'm wondering if it is possible to move my settings from room to room. I'd love to have everything on a thumbdrive and just plug in at the beginning of the day and load my settings up. Then when I leave for the night I can unplug and set it back to its previous state. I do quite a bit of customization of the preferences and the soft keys (especially) that are different from the other guys. Most are used to the stock config and I'd like to not mess with it. Plus I don't want to have to re-create all of my custom soft keys.
If not is is possible to somehow save my setup as a separate user so I can log in and use it and log out and put it back to default? |
Re: Moving Settings
I'd like to know this as well. I do know layouts can be taken with you. You should be able to export your settings from the workstation/settings screen. I'm guessing Avid is working on it.
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
Re: Moving Settings
Currently you could manually go to the Admin account and move the User Settings file between machines. But it is unsupported though… I will look into if it's not the wish list. Thanks, Tom
Tom Graham Avid Audio Marketing Pro Audio and Mixing [email protected] Check out our Pro Mixing Webinars : http://www.avid.com/US/resources/pro-mixing-webinars Avid Pro Mixing Blog: http://www.avidblogs.com/promixing/ |
Re: Moving Settings
Thanks tom!
Re: Moving Settings
Thanks Tom! I will try that out and let you know how it goes.
Re: Moving Settings
could you tell me how this works ? We´d urgently need that feature. No matter it´s unsupported. We updated to V1.4 recently. Thanks ! Bernd Schreiner >:^)=
----- Bernd Schreiner Re-Recording Mixer BR Bavarian Television - Germany http://www.br.de ----- |
Re: Moving Settings
+1 for user accounts on the master module!
Florian |
Re: Moving Settings
Use with caution: These are hidden folders so you may need to unhide hidden files and folders.
C:\ProgramData\Avid\S6\UserSettings.xml C:\ProgramData\Avid\S6\Appsets |
Moving audio region without moving automation? | tokolosh | Post - Surround - Video | 6 | 04-09-2014 06:11 AM |
Moving Plug in settings from 7 to 8 | TCLguy1 | Pro Tools TDM Systems (Mac) | 1 | 02-07-2009 01:08 PM |
Pro tools click settings (1/8 notes or 16th note settings )? | TREBLEBLEED | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-19-2008 09:59 PM |
Moving PPC -> Intel: plugin settings incompatibilities | AINSLIE | Pro Tools TDM Systems (Mac) | 1 | 07-26-2007 08:13 AM |
Moving Settings between sessions? | JLEpperson | Tips & Tricks | 3 | 06-17-2002 07:30 AM |
