24fps to 25fps with Prosoniq Time Factory - help needed
Hi All,
We are currently creating 25fps deliverables for a 24fps Polish film we mixed last December. We are SRCing in Pro Tools to get the length changed and that is not a problem. We have purchased Prosoniq Time Factory 2 and are then putting the files through it for pitch correction. Chris, the engineer in charge will post the settings he is using below. We are finding that: a) it is extremely slow - 4 hours per mono channel for a 144m film on quad core mac pro b) the resultant file is different in length and sync is drifting Can anyone reccommend a more proven (and possibly faster) workflow? Thanks in advance, Matt Chan
http://www.imdb.com/name/nm2050073/ |
Re: 24fps to 25fps with Prosoniq Time Factory - help needed
Here are the settings we are using in Time Factory.
Length = 100% Pitch (semitones) 0 Pitch (cent) -71 Formant (cent) 0 Transpose off Natural pitch off Algorithm DIRAC Standard Best High localization = On The pitch is perfect. And the length of the audio file is correct. But the wave within the audio file is shorter by 3 seconds at the end of the film. |
I use the Time Factory II in a slightly different manner:
Expert settings In FPS 24 Out FPS 25 Pitch (semitones) 0 Pitch (cents) 0 Algo DIRAC Standard (1-3) Good High Localization On system WAVE/BWF No previous SRC length change - varispeed. Sounds good and syncs good. |
The new TF version 2.5.3 seem to change its algorithm list to some new ones.
What are you using today for 24-25 fps conversion? I used DIRAC all the time but its now not presented in the list. There is a new ZTX , ClearScale and quickStratch. What's the best for 5.1 full mix conversion do you think?
Michael Goorevich Sound Designer / mixer www.goorevich.com PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3 MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24 |
This is not, that I am Polish, so I know better, how to to this , but:
if you mixed a movie, you have access to stems: why not using Serato and use different alghorithms for each stem in order to have best quality? I think this is much faster to speed change it, then create full mix from stems... At least for me it worked. best, Kuba PS. I really wonder, how you treated sybilants in dialogs, as my home language is full of them |
And for the DX for me TF is the winner.
Time Factory II 25fps to 24fps PROBLEM | SZE | Post - Surround - Video | 3 | 09-24-2013 06:36 AM |
Using 25fps to 24fps then the converted 24fps to new 25fps. Stay with me on this! | abes | Post - Surround - Video | 2 | 03-01-2013 09:36 AM |
25fps to 24fps help needed | Reckless Erik | Post - Surround - Video | 8 | 11-13-2009 07:39 PM |
25fps - 24fps - Help! | paulspurrier | Post - Surround - Video | 1 | 10-03-2004 02:36 PM |
25fps into 24fps? | Xabi | Post - Surround - Video | 1 | 11-04-2002 03:10 PM |
