Old 01-02-2007, 03:21 PM
tomcat tomcat is offline
Default rotary encoder not working
the HMF que control in the center section eq control doesn't work any more. I am using digi eq3 7 band. I can adjust the que from the channel strip or with the mouse, so i guess it is not a software thing. When i run the rotary test function though, the knob in question seems to function just like all the others.
any thoughts? do i need a new rotary encoder?
thanks,
tom
www.tompaul.com
Old 01-02-2007, 04:11 PM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
Default Re: rotary encoder not working
does the same rotary work for another eq ?
I'm having a week off so won't be able to try this until next tuesday or so but if the test cycles running fine should be an indication nothing is wrong with the rotary .... all tests do work fine right ? Touch test makes the led go red, and if you turn the knob you can see the parameter indication move with it ?
Try another plugin ... first place to start next I think.
Chris Lambrechts
Applications Specialist- Live Sound
Old 01-07-2007, 02:14 PM
PTGuy PTGuy is offline
The same thing happened with me only with a different encoder. Trash all your Digi pref's (including databases) and that should fix it...
Rotary encoder resolution mixboy bob ICON & C|24 2 11-18-2008 03:43 PM
Rotary encoder error on D- Command Fader unit? tstemland ICON & C|24 3 05-02-2006 02:36 AM
Trim on ICON - doesn't map to rotary encoder? GMitchell ICON & C|24 0 09-12-2005 09:53 AM
DAE 6.7b Rotary Encoder Performance Update Avid ICON & C|24 0 11-06-2004 09:34 PM
dead rotary encoder. any tips on replacing? tomcat ProControl, Control|24, Command|8 1 08-06-2003 05:30 AM
