Old 09-30-2012, 08:08 AM
tdawgg tdawgg is offline
Default Newbie w/ Artist Control, transport doesn't function
Hi all..I am a newbie with the Artist Control surface. Install went well, using w/ PT 10.2.0 HD on a intel PC. Everything seems to function as it should, except for the transport section. I wasn't sure if I was supposed to set up the surface as a HUI in the peripherals tab, but when I do, I get the "can't communicate" message in PT.Also, I had checked the ethernet connection box in the setup menu as well as the EUCON box, but went back and un-checked the ethernet box. Searched AVIDs site a bit, but can't find anything related to this issue. As stated, all other functions seem to work fine, but none of the buttons on the transport section light up when connected to a session, but they do light up during power-up. Also, the jog wheel functions seem to work as well (zoom, etc.)
I am sure this is a set-up issue, so maybe someone can help me out?
Old 09-30-2012, 12:12 PM
Default Re: Newbie w/ Artist Control, transport doesn't function
so, I went back and actually read the manual a little (oops), and discovered that PT 10 does not require that the artist control be set up as a HUI or any type of midi interface. I now have only the EUCON box checked, but same issue...everything functions but the transport section...I am hoping someone here has something I can try or misssed during set up, before I contact AVID...thanks in advance, if you do!
Old 11-27-2012, 07:20 AM
Mereijn Mereijn is offline
Make sure you have installed the latest EuControl software BEFORE you update the firmware of the Artist Control.
possible to remap transport key on Artist Control? studioj11 Artist Series 1 11-15-2013 11:28 AM
Is the Artist Mix/Control/Transport worth it? BasketCase Artist Series 7 07-27-2013 05:40 PM
Touching Artist Transport Freezes Up Artist Control in Logic sonofmack Artist Series 1 03-13-2013 08:22 PM
Using Artist Control with Artist Transport? GrievousAngel Windows 2 03-14-2012 03:29 PM
Artist transport as monitor control riddim eric Artist Series 3 12-09-2011 03:01 PM
