Old 09-02-2013, 07:28 AM
Paul Sombric's Avatar
Paul Sombric Paul Sombric is offline
Default How can I install new aax plugins in Pro Tools 11? [solved]
So I've had this problem for about two months now and I still can't figure it out. So I have a bunch of different plugins (all aax) that I used for PT10 but I upgraded and I am now on PT11. But for some reason, I don't know how to install my previous plugins. All I have are just the default AIR plugins and instruments. Is there a way to use more than just those? Please help!
Old 09-02-2013, 08:03 AM
Southsidemusic's Avatar
Default Re: How can I install new aax plugins in Pro Tools 11?
You really need to search this forum better as this question have been asked and answered 10-15 times by now...
You need the AAX plugins and VI's to be AAX64 bit, NOT 32 bit as used in PT10 so go to the developers websites and check when they will have the 64 bit AAX ready. Waves and tons of others have not been ported yet so go and look at the plugins you have. Some have been ported to 64 bit AAX and most of them are free updates.
Follow the AAX64 bit discussions here on the links :
http://duc.avid.com/showthread.php?t=341527
http://duc.avid.com/forumdisplay.php?f=98
Christopher
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 09-03-2013, 02:43 PM
Christopher
Ya I know all of that. I just don't know how to run them on Pro Tools 11. I updated all the plugins to the 64 bit aax from the sites. Why doesn't Pro Tools 11 have a similar folder to the Digidesign folder in previous versions?
Old 09-03-2013, 03:07 PM
Pro Tools 10 and 11 share plugin folders and the plugins updated should be in the same folder as the PT10 plugins.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 09-03-2013, 06:46 PM
Post Re: How can I install new aax plugins in Pro Tools 11?
Press Shift+Command+G (Go to Folder...) and enter /Library/Application Support/Avid/Audio/Plug-Ins. That is where your AAX plug-ins need to reside in order for Pro Tools to load them.
Old 09-05-2013, 05:42 PM
Thank you guys for the help! Everything is straightened out now!
bought heat how to install [solved] Filmusic Pro Tools TDM Systems (Win) 7 02-09-2013 07:43 AM
install loop and install failures Solved.....so far soybalm Windows 1 04-17-2012 08:40 PM
Fresh install of pro tools anyway to find 3rd party plugins Raoul23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-21-2010 03:46 PM
plugins on pro tools install disk djmichael.london 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-03-2008 07:46 PM
Plugins on Pro Tools Install Disk russtay Pro Tools TDM Systems (Win) 3 03-13-2006 08:44 PM
