Re: S3 AVB interface LATENCY is a problem..
A direct monitoring path (with Reverb comp and EQ - on a mini HDX card even) summing to the outputs and HP would have been a great feature for this.
2017 27" iMac 3.8GHz i5, 1TB SSD Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB Musician: http://www.ivanlee.net/ Design Engineer: http://www.propowerinc.com/resume.html |
Interesting responses here! Like I said, I didn't check the latency really long, I plugged in a microphone and recorded it in Pro Tools. During recording I didn't mention that much latency. Alhough it was speech only, so maybe it's harder when it's used for Music recording..
Other point; are there users here who upgraded the AVB IO with another AVB unit? Curious if it works and if there are some high quality options...
Ronnie van Overveld - Sounddesigner - The Netherlands ==================================== Mac Pro Trashcan OSX Mojave, ProTools 2021.3.1 Ultimate, Focusrite Red4pre, Avid S3, Avid PT DOCK, AJA IO XT |
ok, another issue has come up with using the mic pres. So if the latency to monitor the pres is too high for music recording, an option would be to utilise the pres by sending the signal analog out of the s3 and send it to an interface to do the A/D duties with low latency.
but when I assign the analog outs 1+2 to main outs it automatically disables 48phantom power and enables the pad. doh. Why is this an automatic setting? can this be over-ridden? |
Hi, any Avid people here with an answer to this? -
"when I assign the analog outs 1+2 to main outs it automatically disables 48phantom power and enables the pad. doh. Why is this an automatic setting? can this be over-ridden?" Be great if I can get an answer about this, it is not documented in the manual. |
You might find this process useful for measuring your latencies and PT's RTL compensation error http://duc.avid.com/showthread.php?t=368814.
#16
good idea, i will do that and report back
#17
So if i have done this correctly I measure a latency of 8.125ms.
method: Send a pip out of OUT 3 from pro tools, patch the S3 OUT3 into the S3's IN3. Record the pip and measure the delay in samples between the original pip on the timeline and the recorded one. The result was 390samples, at 48khz that is the sum 390/48 = 8.125ms. Last edited by kriszuki; 06-20-2015 at 03:51 PM. |
#18
If that's all you did, it sounds like your PT RTL compensation error is 8.125 ms - not so good! Does "patch" mean connect interface Out3 to IN3 with a cable.?
#19
Yes patch with a trs jack cable between the physical output to input.
#20
I have been reading up on Motu's AVB products and it seems though Apple's drivers are not up to par with the potential of AVB, ie once Apple's drivers improve the latencies will get better.
Anyone at Avid here that can comment on the S3 AVB interface in relation to this? Or anyone using S3 as an audio interface? |
No low latency monitoring in 10.3.1. Third party interface | Greenroomstudio | macOS | 4 | 10-06-2012 07:22 AM |
the fIx to LATENCY!!-using a Focusrite 8i6 Interface & pt10 | shelbybrownjazz | Pro Tools 10 | 1 | 12-20-2011 04:55 PM |
Latency Problem with 3rd party interface. | music4ever | Pro Tools 9 | 0 | 01-20-2011 02:17 PM |
Will interface decrease usb latency | Joe1987 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 05-12-2010 07:49 AM |
Latency on USB Midi interface.... | RingoFire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-07-2002 01:58 PM |
