Old 02-25-2021, 06:22 PM
hendmik hendmik is offline
Default VCA Spill Won't "Un-Spill"
This sounds weird, I know. And I'm sure it's because I inadvertently checked a setting, but for the life of me, I can't figure this one out on my own.
I'm an S1 and Dock user. Tapping a VCA in the Control app, spills the group as I expect it would to the S1 faders, but tapping it again doesn't un-spill them. I have to re-load a session to get access to all my faders again. It worked fine a few months ago, so I can't definitely say whether or not it changed with an update or something I configured.
Here's a video of the behavior if it helps. https://youtu.be/hXwiLE4dLs4
I'm hoping someone can give me some advice here. Avid's support has been unresponsive for over 5 weeks, so I'm bugging you all with my issue. Any ideas?
Old 02-25-2021, 06:49 PM
reichman's Avatar
reichman reichman is offline
Default Re: VCA Spill Won't "Un-Spill"
Depending on your preference settings, your unspill might be the lower left-most soft key on the Dock that is flashing during spill. Does that work for you?
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 02-26-2021, 08:52 AM
EddieJones's Avatar
You are not going crazy. This did use to work that way but we had to take out the unspill part as it caused several bugs. To unspill now, tap the flashing circle bottom left or double tap a Sel button on a VCA on the surface.
Old 03-09-2021, 02:17 PM
Thanks you two.
"Digidesign Midi I/О" in "ProTools 10HD" in "OSX Maverics" electra1006 MIDI 0 06-18-2018 05:46 AM
Cannot spill all layouts to R Spill zone Schottlandru Avid S4/S6 5 10-29-2017 04:21 AM
Any ideas on channel spill for Field Recorder "Functionality"? Ray JB Post - Surround - Video 24 06-14-2016 05:21 PM
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
