Old 09-05-2003, 11:12 PM
toadies toadies is offline
Default loop not staying on grid!!!
I am working on a new song and created a guitar loop. then i notice after about 24 measures the loop is off beat with the grid. Makes no since. I have set the tempo right, using identfy beat which works great. But my problem is it all the sudden got messed up, i'm confused i think its a glitch but it throws off all my tempo for using midi drums and such. does this make since? if not i will post pictures of what it does.
Any ideas what the problem is? Protools really ticking me off, wish i could have time to learn another program.
Old 09-05-2003, 11:20 PM
Default Re: loop not staying on grid!!!
Read the chapter on Tick-Based Timing and Sample Rounding and Edit Operations on page 221 of the Pro Tools 6.1 Reference Guide.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 09-05-2003, 11:22 PM
Roy Howell Roy Howell is offline
Could you have clicked the 'conductor' icon, which defaults to 120 bpm? Does it happen gradually, or does it jump out of tempo beginning at a certain measure?
rh music
Old 09-06-2003, 05:14 PM
i don't think you guys realieze my problem
It seems i only have problems no one else can explain.
Ok I'm taking pictures.
http://web2.airmail.net/coy/
What do you guys think? messed up or WHAT.
Old 09-06-2003, 05:19 PM
Right.. this is exactly what's addressed in the manual.. which I referenced. It's due to rounding between samples and ticks... Do yourself a favour and read the chapter which includes what to do to ensure this doesn't happen.
Rail
Platinum Samples
Old 09-06-2003, 06:14 PM
I did read it, still makes no since i did what it said, to select the measure no the actual region, still no help.
Old 09-06-2003, 06:34 PM
Your picture shows one tempo of 121.55 bpm. Obviously pasting or duplicating a fixed length region to a varying tempo will cause it to drift off the grid. Pro Tools doesn't TCE the regions as they're duplicated to adjust for the varying tempo... although one day that may be a nice feature.
If you have a varying tempo and use the duplicate function, then after duplicating the regions - select them and quantize them to the nearest relevant beat (Ctrl+0).
Rail
Platinum Samples
Old 09-06-2003, 09:13 PM
da BaSsTaRd! da BaSsTaRd! is offline
did your tempo change? last week with PT6.1, my tempo changed by 0.05 bpm for no apparent reason. hasn't happened since, but i use the conductor always now...
i love my apple iPhone!
Old 09-06-2003, 09:22 PM
One of his posts just before my previous one dissapeared.. apparently he has mapped tempo changes in the session.
Rail
Platinum Samples
Old 09-07-2003, 08:56 AM
well i did what you said to do, and i thought it worked, but it didn't. so i deleted that post.
I don't understand what it is doing.
When loop is TCE'd to grid then duplicated out, it doesn't match the grid. STSCRUSHER Pro Tools Software (Win) 1 11-23-2012 10:34 AM
Loop/Grid Weirdness nanoweber 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-10-2010 10:28 AM
Why notes not staying true to grid when change tempo ? KGB2011 Pro Tools M-Powered (Win) 10 08-11-2009 01:29 PM
Forcing the grid to loop length Darney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-06-2009 09:38 AM
How do you fit the grid to your loop??? Capp Tips & Tricks 5 05-12-2002 06:43 AM
