Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 11-20-2020, 02:38 PM
atticmike atticmike is offline
Default Mix in 44.1 but monitor at 192k?
Hi there,
Is it possible to run a session in 44.1 but have the output upsampled for Monitoring?
Gesendet von meinem SM-G965F mit Tapatalk
Old 11-20-2020, 02:50 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Mix in 44.1 but monitor at 192k?
Not from PT. You can run monitor output via SRC box but would not gain anything by doing so
Janne
Old 11-20-2020, 02:51 PM
JCBigler's Avatar
JCBigler JCBigler is offline
Sure, output an analog signal, go through another analog to digital converter and either to your speakers or monitoring system digitally or convert back to analog and into your speakers or monitoring system.
But why? What would the point be? Do you think you can hear a difference at 192Khz?
Justice C. Bigler
www.justicebigler.com
Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools Ultimate 2023.6 / HD|Native-TB
2018 MacBook Pro: six-core i9, 32GB, 1TB, Monterey / Protools Studio 2023.6, / DVS / DAR, L-ISA Studio
Home/mobile: Focusrite Red 8Pre+HD32R / Clarett 4Pre
Road/hotel: Roland OctaCaputre / Apogee One
Old 11-20-2020, 03:33 PM
Or more importantly, will it sound better after the upsampling?(not likely) Seems a bit like converting an mp3 to a wave file........
Old 11-20-2020, 04:52 PM
It actually does sound better when I do this in windows where I can play back files from the player foobar with setting a sample rate of my choosing in the OS output setting of my converter and it does sound better and less mushy. I assume it let's your converter be more precise?
Old 11-20-2020, 04:53 PM
Yes when setting my OS' output to 192k, the playback sounds less mushy and more precise and clear.
Old 11-20-2020, 07:32 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
All current converters I'm aware of up-sample everything so it's pretty pointless.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 11-20-2020, 07:51 PM
Not all of them unless you buy merging or Cranesong.
Old 11-21-2020, 04:48 AM
Teej Teej is offline
My two cents, take it or leave it: the point of monitoring is in the word... you're monitoring what the signal is. If you're mixing in one sample rate but your monitor signal chain upsamples to another, you'll be hearing something other than your actual output. It might sound better to you, but unless you use the exact same signal chain on your mix output when you bounce, you're mixing one thing while hearing another.
Even then, since most delivery formats are 44/48 or 96 etc, you'd have to resample the mix to 192 so it matches what you are hearing and then back down for deliverables...then you've gone even further from the mix.
Monitor at whatever sample rate the project is at and hear what you're actually working on. My Mytek DAC has switchable upsampling...it sounds real "nice", but I leave it off. I want to hear what's coming out of Pro Tools, not some dream to make me feel good about myself.
Maybe I'm not understanding something about your use case but this is what came to mind.
MacMini M1 (2020) / macOS 13.6.4 / PTU 2023.12 / Avid S1
Old 11-21-2020, 08:26 AM
EGS's Avatar
EGS EGS is offline
+1. For monitoring, I prefer a "worst case" scenario. I take an analog output from my audio interface to my monitor controller. I feel this gets me closer to the most probable end-user playback setup.
Click for audio/video demo
Click for resume
192k oddities Norad155 Post - Surround - Video 4 03-02-2010 07:57 AM
What fx do u use if you record at 192k ? fourthtunz Pro Tools TDM Systems (Mac) 7 09-05-2002 06:51 AM
96k vs 192k I/O usinare Pro Tools TDM Systems (Mac) 7 02-06-2002 09:49 AM
Who wants some 192K? Rollerex General Discussion 0 01-26-2002 06:03 PM
