PT10 Fresh Install doesn't show my AAX plugins...
Hi Guys,
couldn't find this on the forum and I'm sure it's a user error somewhere but.... I had to do a complete fresh install of OSX Lion and PT10 (the reasons being OS issue not pro tools). PT 10 no longer sees my Avid plugins folder and consequently doesn't load AAX Channel Strip etc. The folder is definitely there (HD>Lib>App Support>Avid>Audio>Plug-ins) as are the plugs but they no longer appear in PT10. Any Ideas? And when I say a 'fresh install' I literally mean that. NOT Time machine backup but wiped clean start again and am yet to replace any old prefs files or docs etc. Thanks and hope you can help!
PT 10.0.0/Sibelius 7/Kontakt 4.2.4/EW PLAY Composers Collection 3.0.25/AIR Expansion Pack/Superior Drummer 2.2.3/McDsp V5 ML4000, Retro Pack, Revolver, AC Channel 2/Macbook Pro 15" Unibody/8GB Ram/2.2GHz Quad Core i7 2011/OS 10.7.2 Roland V-Drums,TD-8/M-Audio Keystation 61es/M-Audio Fast Track Ultra 8r Last edited by pezdudenyc; 11-02-2011 at 11:08 AM. Reason: *SOLVED* |
Re: PT10 Fresh Install doesn't show my AAX plugins...
I actually had to do a fresh install of OSX Lion for this exact reason! When I first 'upgraded' from Snow Leopard and installed PT10, Pro Tools was not seeing my AAX folder either.
Sounds like it could be a similar problem for you. My suggestion is to Clean Uninstall PT10. Make sure there are no 3rd party plugins or instruments installed. Then install Pro Tools again. Check if it works before installing anything else (including the instrument pack, or ANY third party plugins). If it does work, then carefully install additional plugins/instruments as needed, being careful to check that Pro Tools its still launching properly after each install [this is what I did...] And make sure to TM backup with frequency so you can always go back. If, on the other hand, you still aren't able to get AAX plugins to load, then my recommendation would be to do another fresh install of Lion. |
Thanks anearforgear,
will try the fresh install of PT10 first off and see how I go. I did NOT check the AAX plugins before installing 3rd party stuff so it could be related as you said. Just seems stance that the plugins are right there to see, but do not read! Regards, M
PT 10.0.0/Sibelius 7/Kontakt 4.2.4/EW PLAY Composers Collection 3.0.25/AIR Expansion Pack/Superior Drummer 2.2.3/McDsp V5 ML4000, Retro Pack, Revolver, AC Channel 2/Macbook Pro 15" Unibody/8GB Ram/2.2GHz Quad Core i7 2011/OS 10.7.2 Roland V-Drums,TD-8/M-Audio Keystation 61es/M-Audio Fast Track Ultra 8r |
Re: *SOLVED* - PT10 Fresh Install doesn't show my AAX plugins...
Hello,
yup - clean install of PT10 did the track. FYI - I didn't remove the 3rd party stuff beforehand (sorry, I'm an anarchist ) and it still worked fine. Thanks again! M
Great! Glad it worked. :)
PT10.2 Waves v9 AudioSuite PlugIns won't show up | synkope76 | macOS | 3 | 09-17-2012 12:19 PM |
10.2 fresh OSX install with VI DVD | ArtyMorty | Pro Tools 10 | 0 | 06-12-2012 10:12 AM |
Fresh PT10 install ilok2 drive names too long | Blissful World | Windows | 3 | 02-08-2012 10:57 AM |
Clean install of PT 10 under fresh install of Lion | bortraws | macOS | 0 | 10-24-2011 08:53 AM |
Fresh install of pro tools anyway to find 3rd party plugins | Raoul23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-21-2010 03:46 PM |
