Old 02-20-2021, 03:46 AM
Steon Steon is offline
Default Pro Tools Will Not Play or Record
Hi
Ever since I up graded my software to 20 12 I have'nt been unable to play or record any tracks.
In the case of playing existing projects. If I press play, the play button will light up briefly and at the bottom left of the window I see the word 'pause' lit up in green. It then disappears and nothing further happens.
In the case of recording a new track. If I arm a track to record, activate the record function in the main control and press play. I again, see in the left hand bottom corner the words 'pause record', this time lit in red. This also disappears and nothing happens.
Please help
Old 02-20-2021, 07:53 AM
Default Re: Pro Tools Will Not Play or Record
Things to consider:
#1-You have provided almost ZERO details on the system/setup. Find the link near the top of the screen called Help Us Help You and have a good read so you know what info folks need before we can offer much help.
#2-Close and restart Pro Tools. This works here whenever hitting PLAY does not work.
#3-Uninstall Pro Tools and reinstall the last version that worked(maybe 2012 is not compatible with your OS)
Old 02-22-2021, 05:47 AM
Originally Posted by albee1952 View Post
Things to consider:
System specs from the op's profile
System DetailsNovatech Pro Laptop
Windows 10
Intel Pro Core i7 2.20 GHz 8150
RAM 16GB
Jack
QAPLA!
Old 02-22-2021, 06:53 AM
junkgear's Avatar
junkgear junkgear is online now
I'd also try holding down N when PT is starting, then pick your audio interface in the Playback Engine. Once the Playback engine is set, then I would go in and default your I/O settings. After doing that, open you session and make sure your track inputs and outputs are set properly.
And one last thing; make sure Windows is not using your PT audio device as it's default sound device.
If this does not help, then like the others said, post your system details so we know a bit more about what is going on. Read the Help Us Help You for general troubleshooting and optimization tips and for how to post the proper system information.
Thanks,
Will
Will
System Details
Old 02-26-2021, 05:26 AM
priorytools priorytools is offline
1-check that PT is not on line. . The little clock face on the transport
2-Try changing the hardware buffer size.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Pro tools will not play or record. Please HELP digiuser007 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-23-2008 07:28 PM
Fantom Keyboard to play AND record Midi into the Pro Tools 7 rasianka Post - Surround - Video 0 02-04-2008 06:56 PM
Pro Tools 7.3.` Academic Version won't play/record UnderRated Pro Tools TDM Systems (Mac) 2 03-05-2007 01:33 PM
Pro Tools won't record or play from my harddrive ads 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-07-2007 04:24 AM
