Outboard comp on the master buss
Is anybody (mixing in PT) using outboard comps as an insert on the master fader - via good D/A/D? What are your impressions vs. plug comps?
Re: Outboard comp on the master buss
The master buss insert is (stupidly) post fader, so placing a compressor there is not an option IMHO.
Why, don't most compressor have a make up gain amplifier anyway?
Post fader, meaing if you change the level on the master fader it changes the input to the compressor. Really really f*cking stupid design. Basically the insert point is not an insert point on the master fader, it is a patch point after the master fader.
F*CKING USELESS!!!!!!!!!!! A workaround solution is to assgin everything to a buss, put an insert on the buss, then send the buss to the master fader. |
Not sure why Where finds it so annoying to have to use a Bus & Aux to insert a comp. on the entire mix instead of a Master. Master Faders are just a different critter. What's the problem, Where, are you running out of busses or something?
Lots of people use the TC Finalizer, for example, for precisely this purpose. It's got a really sweet-sounding multi-band comp and EQ, & its Wizard function does an impressive job at guessing pretty sensible initial settings. There's other great units (& combinations of plug-ins) out there also, but IMO this one definitely is a good bang-for-buck choice, generally has a very constructive effect on your mixes, & the I/O to work with a lot of other gear in your studio. |
Hi!
I surely agree with where on the insert being post fader sucks! But as I don´t come to move my master fader very often (why should it be somewhere else than 0 db?) it´s not bothering me anyway. Back to topic: I use a TLA tube comp on the master fader very often with good results. It´s not that I need the compression. I just want this drive of the tube and it sounds good. So the comp doesn´t really compress (ratio about 1:1,2) it just drives my song... [img]images/icons/cool.gif[/img] Greets Markus
www.marcousticaudio.de |
I believe the master inserts are post fader for dithering purposes.
The only time the post fader comp should become an issue is on fade out’s - which doesn’t seem to bother most people. The problem I have with sending everything to an aux is that the headroom is significantly less than the master, and therefore overloads much sooner. |
An insert point, by design, is prefader.
What good is an insert point for dynamics if the fader affects it. Why should I not be able to utilize my master fader without afecting the insert point. the enitre reason for having insert points is to have a prefader send return for dynamics. Understandably so long as you don't change the level of the master fader this is not an issue, however what's the point of having a master fader if you cannot use it. It's nto that I am running out of anything, I should not have to use an additional aux to have a prefader insert point on a buss that supposedly has an insert point. Given we mix via an analog console, and PT is ur secondary recording medium, the entire point is moot fur us, save that IMHO it is incorrect to call it an insert point on the master fader, it is a post fader send. |
Perhaps Doc has some clues on the finer points of what and where to insert in Masters.
Waves SSL master buss comp not working | converted | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 32 | 02-19-2009 09:02 AM |
PSP Master comp, nearest plugin comp to Manley Vari MU? | crizdee | Pro Tools TDM Systems (Mac) | 1 | 05-22-2007 05:21 PM |
does anyone use a comp on an aux buss? | skyking | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 03-16-2005 08:29 AM |
using an outboard comp/limiter on mix buss | badperson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-14-2004 01:38 PM |
Who mixes in the box, but uses an outboard comp on the master fader? | bassmac | Pro Tools TDM Systems (Mac) | 5 | 04-22-2003 02:49 AM |
