Old 02-02-2006, 10:01 AM
fingerz88d fingerz88d is offline
Default Hardware Comp on Master Channel!
Good day ya'll!
Please help refresh my memory.
I'm using a vintage Digi 001 setup with an RME ADI-8 piped through the ADAT ports.
I'm inserting a hardware comp (Cranesong STC-8) on the Master buss through the RME's i/0 (placed after McDSP's AC1, and before WAVE's L2) during mixdown.
Is this subject to system latency? If so, what's the best workaround (life's full of workarounds when using the Digi 001, this we know!!!).
FWIW, I'm Bouncing to disk.
Thanks to any who can provide info!
Old 02-03-2006, 08:58 AM
Default Re: Hardware Comp on Master Channel!
Nobody?
Old 02-04-2006, 09:40 AM
DoubleDigit DoubleDigit is offline
There will of course be some latency in the setup you described, but it should be of no consequence since is across the whole 2-mix. In other words, even if there were 30 seconds of latency (exagerating) it wouldn't matter b/c your whole mix is affected- nothing with be out of alignment with anything else.
Not sure if that's what you're asking....am I missing something?
PSP Master comp, nearest plugin comp to Manley Vari MU? crizdee Pro Tools TDM Systems (Mac) 1 05-22-2007 05:21 PM
Aux Vs. Master Bus Comp / EQ for shows Dylan Post - Surround - Video 1 01-15-2007 03:30 PM
Inserting Harware Comp On Master Bus pablovius Tips & Tricks 10 10-09-2004 02:30 AM
Outboard comp on the master buss bassmac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 06-12-2002 02:21 AM
Waves Ren/Comp-Feedback on Master Ch/LE5 guitates 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-19-2000 09:41 PM
