Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 06-16-2020, 02:22 PM
emf1138 emf1138 is offline
Default Scarlett 2i4 pops/drops/clicks
Mixing from home, I'm using my Focusrite all day, everyday. I'm noticing that I get random pops and glitches when playing. Also, some random crackles when using headphones. I'll stop and playback the same area and and the audio is fine, no errors. I've tried adjusting HW Buffer and Disk cache and it's still happening. "Ignore Errors" is disabled. I've trashed prefs, still happens. Does a drive re-format sound in-order? Any other thoughts?
Trash Can Mac, 32gig ram, PT Ultimate 2019.10, Glyph USB 3.0 drive.
Eric Freeman, CAS
Sound Supervisor/Re-Recording Mixer
Disney TV Animation
IMDB
LinkedIn
Old 06-16-2020, 02:54 PM
Default Re: Scarlett 2i4 pops/drops/clicks
You are a long away from justifying a drive reformat.
Are the click in the recording or happening on playback? (edit: I see clearly on playback)
You tried disk cache... but don't leave it set to "normal" set it to a size that will fully cache your session. Look on the cache meter to see it go green. they start working in the session once it's fully loaded. Now it's set to the best it can be. No other setting makes sense unless you start to run out of memory.
Common cause of headphone "crackles" is faulty headphone socket connections or damaged headphone cable/wiring or sometime RF interference from cell phones, etc.. Are you sure that is not happening here. And it's also not a microphonic headphone volume knob. Give them all a good wiggle.
What sample rate are you running at?
Are you using the interface directly or via an aggregate device? Check Pro Tools has not opened an aggregate device, don't assume (and don't use/get rid of the aggregate).
Try playing back through built in output. Try removing interfaces, all USB peripherals etc. you can and just run the computer with built-in output.
Are you recording to the USB 3 Glyph. What file system? Remove the Glyph drive and try a session off the internal SSD (which will outperform the Glyph so much it's silly)... but I'll eat my hat if the disk is at fault but mostly I just want it removed because its an electrical peripheral connected to the computer.
What macOS version?
What buffer size are you running at now? What happens in you increase that?
If increasing buffer fixes it it might be a plugin issue... and you might need to end up troubleshooting plugins.
Old 06-16-2020, 08:00 PM
No, the clicks and glitches are not getting recorded
I've tried 9, 12, 20 gig
48k/24
Direct.
Yes. Extended Journaled
What macOS version?
High Sierra 13.4.
Happens at 256, 512, 1024
Eric Freeman, CAS
Disney TV Animation
IMDB
LinkedIn
Old 06-17-2020, 12:03 AM
Mmm. So try those other tests. And an obvious comparison is to just play music from iTunes and see if you are hear problems there, though the same interface, and built in output. If it's only Pro Tools and it's in both the interface and build in output... then I'd try playing back a new session with just a stereo audio track and no plugins, adding in some plugins if that works. I'm trying to recall some weirdness with a plugin that did leave click artifacts, can't remember the one, but if that's the cause you'll find your one.
Old 06-17-2020, 04:55 AM
JoelG's Avatar
JoelG JoelG is offline
Might also want to see if there is a newer driver available for your interface: https://customer.focusrite.com/en/support/downloads
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 06-17-2020, 08:28 AM
Joel
No drivers for MacOS.
Eric Freeman, CAS
Disney TV Animation
IMDB
LinkedIn
Old 06-17-2020, 10:00 PM
I made all tracks inactive except for a printed mix stem. There are no plugz or sends on the stem and it's going directly out to the monitors. It did give a minor pop/drop twice, which is not nearly as much as normal. I only stopped and started playback a couple times, but watched all 11 minutes. So, dunno.
Eric Freeman, CAS
Disney TV Animation
IMDB
LinkedIn
Old 06-18-2020, 05:44 AM
its2loud its2loud is offline
Try a different USB cable
Restart the interface
Try different headphones if you’re only using headphones
Check the system sample rate and any other devices you have hooked up to the interface.
Open Audio Midi setup in Mac OS. Make sure the sample rate of the interface matches that of your session. It should change automatically but it could have gotten stuck.
Check your session clock source and the focusrite’s clock source should be set to internal
File Type: jpg 6572E200-6A02-4243-BF05-463490613215.jpg (64.6 KB, 0 views)
Old 06-19-2020, 08:21 PM
I used Quicktime to watch a mix bounce of the same 11 minute program and there were no pops or anomalies. So, it's definitely PT related.
Eric Freeman, CAS
Disney TV Animation
IMDB
LinkedIn
Old 07-06-2020, 07:42 PM
Yeah, I'm at a loss. I've swapped USB cables, reformatted mix drive, and removed kexts and prefs that Focusrite support suggested. Still pops and dropouts. Guess it's time to upgrade the interface.
Eric Freeman, CAS
Disney TV Animation
IMDB
LinkedIn
Crackles and Pops in PT 11.2.1 w/Scarlett 18i8 BassGuyGG Pro Tools 11 1 04-06-2017 11:18 AM
Help!! Clicks and Pops at 96k RCN Pro Tools TDM Systems (Mac) 7 09-16-2012 06:19 AM
Pops & clicks 8.0.3 rotoboy Pro Tools TDM Systems (Mac) 36 03-19-2010 02:52 PM
clicks and pops RustbeltDan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-21-2007 07:52 PM
pops and clicks chahende 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-12-2006 09:21 AM
