Control/DADman flakiness
I am on EuControl 19.12.1.23, Avid Control 19.12.1.3 and DADman 5.3.4.5. I find that EuControl loses its connection to DADman – the Assign tab will re-assign Monitor and Control Room to Pro Tools, and unchecking/rechecking does nothing (it will not lock to anything).
Restarting DADman does not help, nor does disabling and reenabling EuCon in DADman.
https://lukehoward.com/ |
Re: Control/DADman flakiness
Do a complete uninstall of Eucontrol (including user preferences)
Then reinstall. What OS are you on? Also try toggling Eucon off/on on DADman. I had similar problems until it was sorted and then its been rock solid.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Hi Luke are you still getting the problem or did u fix it? Ive just installed the setup here in Melbourne and its doing same flaky thing where I lose Dadman control in dock and can't adjust monitors levels or settings? cheers scanners
www.stevescanlon.com |
DADman does often need to be force-quit though, which is annoying.
Conversely if you want to just pick up where you left off, then you can enable save on exit.
I will look for this good hint, nailed it!
DADMAN and Protools on 2 Separate Computers EUCON PT|CONTROL | Mr Base | Avid S1, S3, Dock and Control App | 2 | 08-03-2019 11:06 PM |
Elastic Audio flakiness (timing, nulls, etc.) | yeloocevad | Pro Tools TDM Systems (Mac) | 13 | 12-02-2010 09:42 PM |
Creative Prodikeys, midi flakiness, some days it works others not at all. | Jenk2k | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-29-2009 11:33 AM |
MTC chase flakiness | Tim R. | Pro Tools TDM Systems (Mac) | 3 | 10-18-2005 09:54 AM |
Import session data flakiness | Tim R. | Pro Tools TDM Systems (Mac) | 0 | 12-11-2003 06:18 PM |
