Re: PT9 will not load. Ilok errors
OK, update!
4th time lucky! Make sure you turn DEP off completely as per the Avid W7 Optimisation list - not just by specific program. Double check it has turned off before attempting to install PT9 - I had done the cmd instruction but for some reason it hadn't stuck & DEP was still turned on. Re-ran the cmd instruction & rebooted & DEP was now turned off, ran the installer & PT9 went in A-OK. HTH - good luck!
Chaz Shifting Sands Audio www.shiftingsandsaudio.com soundcloud.com/shiftingsands Asus X79 Deluxe | i7 4930K @ 4.1 | 32Gb Ripjaws CL9 GBLZ | Radeon R5 230 | Win7 Pro (64) | 256Gb Samsung 850 SSD | 2x 1Tb Seagate SATA | 250Gb Samsung EVO SSD | 128 Samsung SSD | Antec 650W | ProTools 11.3.2HD, 10.3.9HD, 12.5 | Cubase 9.0.20 Pro | Nuendo 8 | Studio One 3.2 Pro | RME UFX | 2x Octopre Mkii Dynamic | Alphatrack | DTouch | Logitech G510 | Kensington Trackball | Yamaha UX256
ChazC, THANK YOU! This solved my problem AND my command 8 is working under Pro Tools 9 so I had a double bonus today.
Mat
Pro Tools HD 10 & 11 Profire 2626/Focusrite Octopre MKII Mackie Control Universal Pro Intel Core 2 Quad Q6600 Intel MB P35 Express Chipset 1333Mhz FSB Memory: 32GB DDR3-800 OS:Windows 7 Ultimate |
Good morning folks. I am also having problems getting PT 9.0 to load. When I first start, I receive an Operating System Error dialog box:
Operating System Error Cannot create a file when that file already exists. ID: eOS : 183 / path : 3 When I exit that dialog box, I then get a ProTools error: ProTools.exe Application error The application was unable to start correctly (0xC0000142). Click OK to close the application. I did a full install with DEP turned off and my Anti-Virus (Kaspersky) disabled. I also installed the latest iLok drivers as well as MBox 2 drivers. This is on a Dell Latitude E6500 that previously ran ProTools 8 LE. Any advice or troubleshooting help would be appreciated. Thank you in advance, Bob Foery Technical Director, Annapolis Summer Garden Theatre [email protected] |
(RESOLVED) Re: PT9 will not load. Ilok errors
Folks,
I went through the Windows 7 optimization techniques and found that permanently running PT as Administrator resolved this issue. Regards, Bob Foery |
Same here, tried all the work-arounds found and then some..........not I'm stuck with no PT's, at all.
AVID/iLok............there are definite driver issues !!!!
Healing the world through music................. Sony Vaio Laptop|2 Core P8700 2.53 Ghz 8 Gb Ram|Win8 x64 PT 9.0.6|Cubase 7|Samplitude Pro X|Reason 5|Spectrasonics|Komplete RME BabyFace|AxiomPro49|Akai LPD8 |
Pro tools 9 won't load as HD! Have a core card installed and an HD license on Ilok | Blake Henderson | macOS | 17 | 07-07-2012 12:42 PM |
PT9 won't load anymore....ilok not seen usb not supported?? | bryanjollie | Windows | 3 | 03-07-2011 08:30 AM |
Need help with iLok plugins not allowing PT to load | lemonrico | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-16-2009 12:25 AM |
Problem: Velvet on iLok, but can't load into sessions | sirgant | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-21-2007 02:01 PM |
Protools 6.2.3 Slow Load Time on G5- Why? iLok? | Mt.Everest | Pro Tools TDM Systems (Mac) | 0 | 05-23-2004 10:45 PM |
