Old 07-15-2010, 01:38 PM
Firechild Firechild is offline
Default MIDI hanging notes /echo effect...
I am new to Pro Tools,but very MIDI experienced person, coming from Logic.
I have a really strange problem.
While just playing a Virtual instrument, for example NEXUS or Kontakt4 or PLAY from my MIDI keyboard through Emagic AMT8 with the transport stopped it often comes to a point that my live playing notes stop and I will hear my just played sequence playing back, like a loop or from a MIDI buffer. After that I have to hit Play /stop to empty the MIDI buffer and I can play some notes again...
Why? I have disabled the plugin delay compensation without different behaviour.
I really wanna like Pro Tools after cashing out for a HD system...
8 [email protected] / 10.5.8 / PT HD 8.0.3 / 16 GB RAM / HD2 PCIe
Old 07-17-2010, 01:30 AM
Default Re: MIDI hanging notes /echo effect...
Bump
Old 07-17-2010, 03:31 AM
crizdee's Avatar
crizdee crizdee is offline
Hard to diagnose without knowing more about your session setup. areas to look at...
preferences / midi. look at the pulldown list and see if its set to "first selected midi track"
global midi offset is set to 0 samples
under setup / midi / midi studio. check there is only one icon for your midi interface.
Do you have any plugins on the master channel?
Any other plugins in the session when you are testing this?
is it happening on all sessions or just one?
Whats your hardware buffer set to?
Got the latest driver for the amt8
All virtual instruments are up to date?
The AMT8 is connected directly into the computer and NOT through a USB hub!!
Local midi is turned off on your controller keyboard!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 07-17-2010, 04:37 AM
Thanks for your reply. I have now tried with a MOTU 8Pre built in MIDI interface, same result, switched MIDI keyboard,same result.
HW buffer 256 samples.
Old 07-17-2010, 04:53 AM
i found a workaround. I set Host Processors to 7 instead of 8, now everything is smooth...strange...
Old 07-17-2010, 07:24 AM
crizdee's Avatar
Yes setting your processors to odd numbers is recommended! especially for using VI's. some VI's just don't like it when the processors are set to even numbers? they overload the CPU and cause all sorts of problems.
Glad you're sorted.
Chris
Producer, Engineer,
www.ukmastering.com
Old 06-09-2017, 06:47 AM
[email protected] ali.talaea@yahoo.com is offline
Hello all,
I am facing the same problem, a looping noise crackling when I am playing back midi until the notes just hand indefinitely, i then have to stop playback , in that only session.
System Windows 8.1, Focusrite Scarlett 2i2
preferences / midi. look at the pulldown list and see if its set to "first selected midi track" -- Yes
global midi offset is set to 0 samples -- Yes
under setup / midi / midi studio. check there is only one icon for your midi interface-- No devices are seen here
Do you have any plugins on the master channel? -- Yes there was a reverb I disabled it but still problem persists
Any other plugins in the session when you are testing this?no
is it happening on all sessions or just one?Just this session
Whats your hardware buffer set to?1024, and processers 3 instead of 4
All virtual instruments are up to date?yes
Please help
Old 06-09-2017, 01:29 PM
You dredged up a 7-year-old thread(plus adding to other threads as well). You will be much better served to post a new thread, in the proper section and with great detail about your computer/interface and midi controller(s). One fresh, clear and concise thread is better than "thread-jumping" all this old stuff(which may or may not be related)
Midi notes hanging FMajor MIDI 6 06-14-2010 03:39 PM
Hanging notes and midi problems Dynamoe Pro Tools TDM Systems (Mac) 5 03-10-2009 10:16 AM
Hanging Midi Notes hearttimes Pro Tools TDM Systems (Mac) 0 09-17-2005 08:29 PM
Digi? any fix for midi notes hanging yet? crizdee Pro Tools TDM Systems (Mac) 2 08-31-2005 10:30 AM
Midi Notes Hanging in 6.9 hws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-22-2005 01:24 PM
