Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 09-21-2020, 02:49 PM
rhumphries rhumphries is offline
Default routing within pc
What's everyone using to route signal within their PC? i.e so I can route audio from a web browser and into protools, etc.
On mac I've used Soundflower. On PC I've been using Virtual Audio Cable so far, but it gives me lots of dropouts. What else is around that works well.
•HD Native, Omni, BlackMagic Intensity, i9 9900, 32GB Ram, Windows 10 pro PT 2020.5
www.TakomaMedia.com
Old 09-21-2020, 08:33 PM
Default Re: routing within pc
You can avoid any third party routing software by recording a file from the Windows “Stereo Mix” device and record with anything and import the audio file into Pro Tools.
Old 09-23-2020, 12:28 PM
Indeed, I have never been able to make a direct path into PT without going out and coming back into inputs on my interface. Pretty sure you could do it with Audacity(free) or some other free software. You might also consider Wavelab Elements(which is also handy for burning audio CD's and mastering)
Old 09-23-2020, 04:39 PM
Yeah, that's how I do it at my studio where everything is terminated on the patchbay, but I'm working from home a lot these days and trying to figure out a way to do it in the box.
@Darryl Ramm, Are you able to use the "Stereo Mix" device as an input to Protools using Asio4all? I experimented with it today but had no luck so far.
www.TakomaMedia.com
Old 09-24-2020, 08:52 AM
I would not inflict ASIO4ALL on myself. You can't just "ASIO4ALL" the input you have to aggregate that with an output in ASIO4ALL... Pro Tools cannot work without an output... and you cannot aggregate to a HD Native interface with ASIO4ALL.
Old 09-25-2020, 09:07 AM
Thanks for your insight. It's been helpful. My home setup isn't using an HD Native interface at the moment, which is I think I need to use Asio4all-- so I can monitor Basehead, Vocalign, etc through PT. If there is another option, I open to it. I've been Mac-centric for the past 15+ years so it's taking me some time to catch up with PC best practices.
www.TakomaMedia.com
Old 10-19-2020, 12:32 AM
Philharmonic7 Philharmonic7 is offline
I know you mentioned virtual audio cable, but I suggest downloading VoiceMeeter Potato. It’s the same developers as virtual cable, but it’s a more complete software. The GUI looks like a virtual mixer, and I use it as my virtual router within the PC ecosystem. It can be daunting trying to figure it out, but there’s a ton of tutorial in YouTube to get you started. Give it a shot.
Old 12-09-2020, 04:33 PM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
On a related note, does anyone have trouble with Protools forcing across the board sample rates?
I have a HDNative>Omni system at 48k (post standard) and I'm trying to run with Source Connect Now (which uses 44k1).
I'm using a Zoom F6 as the I/O for Source Now and it works fine until I launch ProTools, at which point I get a pitch shift and glitches on the return loop.
I've tried all the settings in the Zoom Audio Driver but it makes no difference at all, as soon as PT launches the clocking falls apart.
Edit.... Fixed it. The Windows sound settings seem to override the specific OEM driver settings.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest
Another Folder Track bug: Soloing a Routing Folder doesn't solo routing bus XJENSEN Pro Tools 2020 7 04-24-2020 07:29 AM
VCA routing danyg Pro Tools 12 2 11-02-2015 12:39 AM
routing skiffle General Discussion 5 04-04-2014 01:14 PM
Routing out Logic 1 & 3, anyone know basic Logic routing? soundonsound Pro Tools TDM Systems (Mac) 2 06-04-2008 10:42 PM
routing lcouri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-09-2001 06:39 AM
