Old 06-27-2002, 12:46 PM
Shak Shak is offline
Default Thinking of making a Switch
Hi
I am thinking of making a switch from the P3, Intel chip to Asus A7V333.
My question is will it mess up all applications when i switch motherboards.....
I just bought Digi001 but i use Logic a lot and i tried playing with PT.....i think the main use of PT (atleast for now) would be to bounce tracks off Logic as wav and bring it in PT and take advantage of better quality...do i even need to switch motherboards then?????? Thx
Old 06-27-2002, 02:32 PM
Default Re: Thinking of making a Switch
Greg
Thanks for your advice...yeah my only use of Pro Tools would be brings tracks in from logic and add a few plugin...but for that i can always get more RAM and i think it would do that job...
I am only using digi interface for godd quality sound...the software at present is a high priority...thx again
Old 06-27-2002, 09:19 PM
G.roots G.roots is offline
You are most welcome and have fun!
Musician/Electrical Engineer
San Diego, CA
Old 06-28-2002, 01:49 AM
It is not a good idea to attempt a motherboard "transplant." Although it has been done before, the chances that you will encounter serious errors is VERY high! Even if you manage to get it halfway done, your performance will be seriously compromised. NOT A GOOD IDEA AT ALL!
I can not see why you would want to upgrade if you are only importing stereo tracks. Your current system should be able to handle these sessions fine unless you add several plugins. Remember, your tracks have already been captured with whatever IO you had acquired them with. Simply transferring from Logic to PT will not do much for the quality of the sound at this point.
You will find many more uses for a new system if you choose to build it! I recommend going for the new system but you should convince yourself why.
[img]images/icons/grin.gif[/img]
Good luck,
Greg~
San Diego, CA
Thinking of switching from PC to Mac. Will my plugs switch as well? TeleKing 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-23-2009 09:45 AM
Thinking of making the Apple switch... Couple of questions JChance Pro Tools M-Powered (Mac) 11 10-09-2007 05:47 AM
Thinking of making the leap to the wintel world. PTPerson Pro Tools TDM Systems (Win) 17 04-13-2006 01:29 PM
Thinking of making the switch to MAC herbyherb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 03-02-2006 07:23 PM
Thinking about making a move... steelronkeel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-09-2004 07:37 AM
