Old 11-10-2018, 03:52 AM
Talisker Talisker is offline
Default Audio files show up in the folder, but not in the clip list
Hi everybody, I have the following issue (and before you ask, my setup is in the signature.)
I just opened a session, that I haven't been working for a while, and it showed up empty. But the audio files are all in the audio files folder how come, there are not in the clip list and the session. Also the session folder is missing any backup files or midi files. I hope this is something that I myself was doing wrong and can avoid in the future (apart from more frequent manual backups.
Mac Mini M1, 16 GB Ram, OSX 10.181.1,Focusrite Scarlett 18i20,Behringer ADA 8200,Pro Tools 2022 2xGlyph hard drive 750GB
Old 11-11-2018, 08:05 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Audio files show up in the folder, but not in the clip list
Hi, No idea how that happened. Just make sure you back up the whole session in the future.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 11-11-2018, 11:47 AM
crizdee's Avatar
crizdee crizdee is offline
Are the empty waveform outlines where the audio used to be still on the edit page? have you tried re-link audio in the workspace browser?
This would only usually happen if the audio location was changed after the recording or the file path name was changed after the recording.
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-11-2018, 01:00 PM
cwsand's Avatar
You're lucky for that! You should be able to import the files to the session and Spot them to the correct locations on their tracks. Could take some time, but it's doable.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 11-12-2018, 06:17 AM
Well, since I noticed that the entire session was back to template stage and there were no automatic back ups left I realized that something went terribly wrong here and it was most probably my fault whatever it was.
Luckily it was no clients song it was my song and it had not developed very far yet. So I could rerecord it quite quickly.
Still would like to know what happened.
but thanx for your answers
Old 11-12-2018, 08:22 AM
If you had a backup of the session on another drive, and that backup was mounted while you were working, Is it possible you were actually working on the backup and then backed up over it? I've seen that happen way too many times...
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 01-12-2019, 12:43 PM
Daveyr2 Daveyr2 is offline
BUMP! This is absolute madness that they took this function out! Way to go AVID!
A big Computer, with a BIG heart!
PT10 - Clip List always empty (no clips show) quangaroo macOS 6 04-19-2019 07:52 AM
Audiosuite new files into clip list, not replace [solved] mikevarela Post - Surround - Video 2 03-16-2017 03:41 AM
Pro Tools 11 Online Record - Recordings do not show up in tracks or clip list JKayL Pro Tools 11 0 04-30-2015 10:56 PM
Deleting files from clip list and missing files colinato Post - Surround - Video 1 10-22-2013 09:52 AM
Mt. Lion Finder Doesn't Show # of Files in Folder Logichead Pro Tools HDX & HD Native Systems (Mac) 2 12-24-2012 08:58 AM
