Besides PT Le and Logic, what softwares can I use with 001 ??????
Hi, What softwears I can use w/ 001 besides LE and Logic ?
Cakewalk, Sound Forge, Acid ? What about softsamplers, Gigasampler, Unity ? I also use CDXtract, Reaktor, B4 and Pro Five by Native instruments.... Can I use this stuff with 001 ? Thx in advance for any help ! The only reason I want a 001 instead of a Layla or a delta 1010 is cause I love Pro Tools Software. Is PT LE similar to the TDM version (I know, no TDM precessing, 24 tracks limit, I mean is FUNCTIONS similar ?_
- e.l - ps: btw...sorry for my english. ;-) |
Re: Besides PT Le and Logic, what softwares can I use with 001 ??????
Well, I can say that Soundforge, Acid, and Cakewalk seem to work with it pretty well. All audio in windows will go thru the digi except if you are playing a CD in the cd drive.
renuir, Thx !!!!
This means that Cakewalk will see the 18 I/O from 001 ? Or it will see some kind of Direct Driver (only analog 1-2 pair) ? Direct-X plugs will work ? What about the MIDI ports ? did Cakewalk recognizes it ?
Another doubt that Comes to my mind....
I heard about the Exploding Sound Phenomenum on 001/Macs. Is 001/PC user facing this problem as well ??? btw...sorry for my english !
The Digi hardware will work with any 3rd party software platform (like those you mentioned) but you will be limited to 2 channels I/O. You have to use the rather limiting and slow Digi Wavedriver. DirectX plugs will work fine but any soft synths you may be hoping to use will suffer from a very noticable and very annoying latency.
LH |
It is not true that the 001 will work with 'any' 3rd party platform. It will not work with Cubase at all. Nor will it work with some mastering apps if you are also using Logic - reason being is that one must disable wave drivers in Windows to use Logic, and then most audio progs will not recognize the 001. T-racks is one that will not. I get around that by also having a Darla card on my PC for mastering. Pain in the ass.
Your softsyths and samplers should all work fine as long as you use them from within Logic. Not sure if all the stand alones will work from without. |
best naming softwares | feltonisounds | General Discussion | 1 | 06-07-2012 02:21 PM |
Pro Tools took over other softwares | Draganon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 07-25-2009 05:22 PM |
DIGI002 with other softwares ?? | Mr_Sarenk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-06-2004 09:02 PM |
MIDI softwares for PTF? | vertaco | Digidesign Hardware & Software | 0 | 09-23-2001 10:42 AM |
Compatibility between PTF and others PT softwares | alemorais | Digidesign Hardware & Software | 1 | 03-24-2001 09:49 AM |
