12.5.2 delay compensation issues
I have recently switched from my PC to a MacBookPro 2,5 (Retina Mid 2014) trying to get rid of all the bugs on my Windows 7 machine. (mostly crashes)
I got less crashes and a much more stable system.... But I have delay compensation issues right now! Right now I work on older sessions, created on a Pro Tools 8 a long time ago. But I also did save a copy of the session to a new harddrive! After recalling from a session template and turning HEAT on, the whole session sounds weird...drums are off, phasing occurs! I have to reboot the computer and then it sounds ok! Turning off Pro Tools and reload does not help! My system: Pro Tools 12.5.2 on OSX 10.10.5 , MacBookPro (Retina 15, Mid 2014), 2,5 Ghz, 16 GB, Sonnet Echo Express SEII, HD NATIVE, HD I/O 16x16, HD192 I also updated all the plugins I´m using in the session... This is a pain in the ass! Any suggestions? Last edited by dropking; 07-12-2016 at 02:13 AM. |
Re: 12.5.2 delay compensation issues
Even without plugins - only routing 4 Tracks into a mono bus ... no compensation!!
I´m so sick of it!! Amateur Tools no Pro Tools!! |
I haven't experienced this. Only flaw that I know of is that sends are only compensated if you have HDX, I don't know why.
I´ve checked everything and found out that the recording engineer has set some delays in the channels to tighten up the phase on the drums.
Nothing on the kick and that was the one I have bounced to disk! After I have turned all the delays off everything was fine.... We tried the same on the reording system (Pro Tools 10) and everything was fine, with all delays on!! Hmmm?? |
Delay Compensation issues in PT11/12 | ggegan | Post - Surround - Video | 11 | 07-09-2015 05:54 PM |
Pro Tools 11 issues (delay compensation,cpu spikes) | andycallison | Pro Tools 11 | 0 | 05-13-2015 12:50 AM |
Issues with Delay Compensation | ilee | Pro Tools 9 | 4 | 12-26-2013 04:25 PM |
Delay compensation issues | studer80 | macOS | 2 | 12-11-2012 06:49 AM |
Waves Q Clone + PT8 Delay Compensation = Issues? | acacia | Pro Tools TDM Systems (Mac) | 5 | 01-23-2009 11:52 AM |
